Key Fob
Old Dec 1, 2008 | 07:50 AM
06detroitgxp's Avatar
Default Key Fob
My keyless entry just stoped working out of no where, I changed the battery and still nothing. Any Ideas, I really dont want to go to the dealer and have to pay a ton for a easy fix.
Old Dec 1, 2008 | 08:28 AM
Kazmaniac's Avatar
You can try to re-sync the remote w/ the vehicle, instructions I thought were in the manual.
If not, IIRC one of the GXP guys had a smoked board that he replaced.
Old Dec 1, 2008 | 08:41 AM
Yeah I looked in the manual I could find anything
Old Dec 1, 2008 | 09:06 AM
Scarhead's Avatar
The 2004 (or was it 2005) and newer GPs' key fobs MUST be programmed using the Tech II scanner, there's no backyard way to do it.
Old Dec 1, 2008 | 09:08 AM
yeah it's a 06, do you have any idea how much it's going to cost?
Old Dec 1, 2008 | 10:23 AM
neilownz's Avatar
one of my fobs needed to be replaced because of a bad contact. could be something like that. they can also be programmed using the dic... it should be in the manual.
do you have a spare fob? and does it work?
Old Dec 1, 2008 | 01:21 PM
My spare fob has never worked, I bought the car used 3 months ago
Old Dec 1, 2008 | 01:31 PM
neilownz's Avatar
get a couple new ones off ebay and have them programmed. some items say like programming instructions included etc. locksmiths can do it too i guess. might be cheaper than a dealer.
Old Dec 1, 2008 | 02:22 PM
jdwilks's Avatar
I know one of my key fobs was bad right when I bought it. After I signed papers the dealer took me out to demo the remote start and it would lock the car then just set off the alarm when you tried remote start. It was GM certified so they took care of it but had to get a key fob to do so
Old Dec 2, 2008 | 12:00 PM
Took the fuse out to see if it was burnt it was fine so I put it back in about 30 seconds later and it works again now wooo!!
Old Dec 7, 2008 | 07:40 AM
GXPJIMMY's Avatar
I had to re-solder the battery hold down to the circuit board. The contacts on each side of hold down had broke away from board.
