Whats a 4T65E-HD transmission worth?
Now you have my attention
Just curious but will an L67 bolt up to this transmission? Or is it a different bellhousing pattern.
Also is it possible to bolt up any LSX motor to this transmission? Just in general..
Because if they are really going for that cheap I'm going to look for one for my buick lol
They are the same as a buik 6 cylinder transmission. I am positive of that. The bolt pattern is the same as the transmissions behind the 3800 series camaros. The only thing stopping it from working with that transmission is the fact that the start is mounted on the transmission and not the block. I'm removing everything from the engine as we speek to see if i can make anything work or make a bracket to make it work.
