ZZP high ratio rockers
Old Jan 24, 2009 | 04:18 AM
StealthV8's Avatar
Default ZZP high ratio rockers
Anyone using these on a ls4? ZZP is claiming 18 whp gain on a 5.3L chevy 1500
http://www.zzperformance.com/grand_p...=953&catid=104
Old Jan 24, 2009 | 08:18 AM
06 SS's Avatar
The 1.85's wont clear without some machining, I imagine a 1.9 will need some as well. I would make damn sure they are compatible with the DoD lifters as well.
Old Jan 24, 2009 | 02:36 PM
Nacho SS's Avatar
They won't clear...the highest we can go with the DoD lifters is 1.8 if I remember someone saying that on here.
Old Jan 24, 2009 | 05:27 PM
StealthV8's Avatar
so you guys think lossing dod and swaping lifters is worth it? or should i just stick with the 1.8?
they seem to work with the dod on the g8 but i guess thats cause its a totally different engine?
Old Jan 24, 2009 | 05:36 PM
neilownz's Avatar
what wont clear?
Old Jan 31, 2009 | 07:16 PM
Area47's Avatar
harlan sharp 1.8 rockers from summit. not the copied and failed version that zzp does.
Old Jan 31, 2009 | 09:47 PM
La06GXP's Avatar
I have the Harland Sharp 1.8 rockers and they work just fine with DOD. I have had them on my car since about 40,000 and have had no problems. (I'm at 99,500 miles). I would recommend that if you do the rockers to also install stiffer springs and stronger push rods. At first I had only installed the rockers and I did have valve float. I have the Comp Camps Hi-Tech push rods and 918 springs. Here is a thread showing one of the first people to do this: https://ls1tech.com/forums/ls4-front...tall-pics.html
Old Feb 4, 2009 | 08:24 PM
07gxpgray's Avatar
according to zoomer they fit fine!
Old Feb 5, 2009 | 03:01 AM
StealthV8's Avatar
ya and have installed them on a ls4
"2nd dyno - Installed ZZP rockers and the car gained 1 psi of boost and picked up 18 HP to the wheels! Dyno test was done on a '06 Monte SS 5.3 liter with a turbo kit installed."
http://www.clubgp.com/newforum/tm.as...e=1&s=#4766578
Old Feb 5, 2009 | 07:24 AM
Mels SS's Avatar
I want to get the rockers and I want to totaly get rid of the DOD. How can I do this?
Old Feb 5, 2009 | 07:33 AM
fastLS4's Avatar
Tune it out with HP or a custom tune.
Old Feb 5, 2009 | 07:45 AM
Mels SS's Avatar
Yes but I won't to change the lifters and all
Old Feb 5, 2009 | 08:14 AM
06 SS's Avatar
You folks who claim there is no problem with them do know the OP is NOT talking about 1.8 ratio rockers, but 1.9, right? You all followed his link before commenting I assume.
Old Feb 5, 2009 | 08:17 AM
LS4SPEED's Avatar
Mel I believe if you want to get rid of all the DOD parts, i.e. lifters and push rods. I think you should also replace your camshaft, to a non dod cam.
Old Feb 5, 2009 | 08:19 AM
Brian396's Avatar
...x2
Old Feb 5, 2009 | 09:58 AM
Bryan921SS's Avatar
Also when getting ride of DOD/AFM you will use a different valley cover, which also opens up the intake mani options.
That would be the quickest route to swapping intakes to an LS1 or LS6 intake.
Old Feb 5, 2009 | 10:39 AM
neilownz's Avatar
still have to relocate the oil pressure sender if you want real intake manifold options.
Old Feb 5, 2009 | 11:25 AM
Mels SS's Avatar
Yes I want to do all the above to remove the DOD
Old Feb 5, 2009 | 03:20 PM
Mels SS's Avatar
So what all has to be done and please give all parts and #'s Because I really want to do this and then get the LS6 intake. also thanks alot guys.
Old Feb 8, 2009 | 09:37 AM
07gxpgray's Avatar
Yes I know the OP is talking about the 1.9 rockers. I have been in contact with zzp about this....the monte is running the 1.9 with stock springs and everything is fine with the dod lifters as well. I am guess brcause these are modified stockers is why everything is working fine.
