Painted Engine Cover
Just make sure to do very light coats and then let dry followed by another light coat. It looks like its never going to change color but trust me it does.
The look of: "man, I really don't want to do this shyt this late at night!!"
sprayed with Dupli Color Adhesion
carefully spraying layers of black(universal Dupli Color Black),.....took a while to get it too look like this! LOL!!
Painted the "5.3L V8" letters with universal black touch up Paint!
Did these too!!
wet sanded from 800 to 1500 grit
The final project:
I love the look of the engine itself, and I am in favor of just dumping the cover all together if it isn't needed.
I had mine off and took it in for dealer service and they yelled at me. Asked me where it was etc. But when I asked them about what it does they didn't have an answer.
With the braces, I wet sanded (there were still plenty of black paint remaining on them) but sticky enough to adhere to paint!
Then I sprayed em with the same GM Silver Dupli Color and 2 or 3 shots of clear. And LOL!! about the engine cleaning!! When and/or if I'm around, its a bet!!
Powder coating is a type of dry coating, which is applied as a free-flowing, dry powder. The main difference between a conventional liquid paint and a powder coating is that the powder coating does not require a solvent to keep the binder and filler parts in a liquid suspension form. The coating is typically applied electrostatically and is then cured under heat to allow it to flow and form a "skin." The powder may be a thermoplastic or a thermoset polymer. It is usually used to create a hard finish that is tougher than conventional paint. Powder coating is mainly used for coating of metals, such as "whiteware", aluminium extrusions, and automobile and motorcycle parts. Newer technologies allow other materials, such as MDF (medium-density fibreboard), to be powder coated using different methods.
I will get pics up when I get it installed, it's hanging in the garage drying right now. Kind of looks like a baboons *** though
HAHAHAHA
