STB's Arrive
Old Feb 23, 2009 | 11:03 PM
speedshifter's Avatar
Originally Posted by neilownz
its actually not dented. he cuts out a bit then welds a piece of steel in there then primes it.
Well in that case, that justifies the price he is charging. Thats not a 5 minute project.
Here is the one I was talking about earlier that comes pre-bent from GM:
I just worked on an '02 Impala today that had one.
Old Feb 24, 2009 | 05:58 AM
cherry gxp's Avatar
is there somewhere we can get the braces at other than this guy (DR)? The bars seem cheap enough, I'm sure we could actual have braces machined ourselves with correct measurements.
Old Feb 24, 2009 | 07:01 AM
LS4SPEED's Avatar
Make a cardboard template, trace it out on some 1/4 flat steel and cut it out witha jig saw. That's what I'm gunna do when I get time.
Old Feb 24, 2009 | 08:22 AM
1/4 flat steel will flex way too easily. You need to use something that is boxed like the GM brace. Honestly, for as cheap as these braces are you can't go wrong. You are better off buying the pair of braces and modifying the front one to clear the alternator. I'm not what that Impala one costs that I posted a pic of above, but when I get a chance I will find out. That one I stole the pic from is on ebay for $19 right now.
Old Feb 24, 2009 | 08:33 AM
LS4SPEED's Avatar
Talking bout the brackets not the actual strut tower brace. Don Rome makes some brackets so you don't have drill into the strut tower to mount the brace, he (Don Rome) makes them out of aluminum flat stock. Easy to work with. But steel is cheaper and I'm going to paint them to match the engine bay anyways.
Old Feb 24, 2009 | 07:42 PM
Cherry said braces, thats why I was confused. The same guy also make billet core support braces that are flat stock. They are for show, not for strength IMO.
Old Feb 25, 2009 | 06:04 AM
LS4SPEED's Avatar
Your right, I read right over "braces". But I do think he is talkin bout brackets? No?
Old Feb 25, 2009 | 08:27 AM
cherry gxp's Avatar
Yeah, the brackets to mount the bars is what I'm talking about Sorry for the confusion. We can buy the stb's cheap as crap, but the brackets so we don't have to drill is what I'm asking about, anywhere else to get those?
 Michael S. Palmer
Old Feb 26, 2009 | 02:11 AM
ckso226's Avatar
you could get the ones of D'romes site which are a direct fit with the GM stb's. or you can get a zzp stb but ull need their own special brackets.
Old Feb 27, 2009 | 12:52 PM
plmcrzy's Avatar
Here's a couple of pics of Flis moded bars and dons brackets
Old Feb 27, 2009 | 03:11 PM
keviiinn's Avatar
that looks great man. do you get any hood rub on that front bar?
Old Feb 28, 2009 | 01:32 PM
  #32
08_SS's Avatar
I used Don's brackets (excellent machining and worth the money IMO) and modified the braces myself.
All I needed to do was put the bar in my bench vise, below the jaws, into where the pipe clamp part is. The brace went on one side, and an impact socket went on the other side - sitting flush in the "dent" that is already there. A few turns of the vise handle and it was clearanced enough to not come close to even touching the alternator. The bar doesn't rub on the hood either from what I have seen, but I only look under the hood maybe once every two weeks or so to check the oil and fill up the washer fluid.
Old Mar 1, 2009 | 07:29 AM
  #33
plmcrzy's Avatar
Mine doesn't rub on the hood either, and these bars really do perform well, I live in the mountains and theres alot of twisty curvy roads, and you can really tell the difference in the corners
