Cam installs
Old Feb 28, 2009 | 11:58 PM
Panther427's Avatar
Default Cam installs
For the few of you that have done the cam install could you tell me what else had to be done. I rember reading the issue between the 3 and 1 bolt cam gears. But what else.
How much was the total for parts besides the cam. Not to afraid of this mod just wanna know what else i need to buy since a few of you have taking the pluge already. No point in donig this blind since a couple of you have done this. THANKS
Old Mar 1, 2009 | 12:27 AM
neilownz's Avatar
matters what all you want to change and what year your car is. if you have a 05-06 vehicle it will be 3 bolt cam already. head/cam bolt/gasket kits will be needed depending on if you change the lifters or not. read through the applicable threads a few times.
Old Mar 1, 2009 | 01:05 AM
CenTexSS's Avatar
PM Mixerda. He has a cam in his 07 Impala SS
Old Mar 1, 2009 | 01:13 AM
Panther427's Avatar
Ya i have an 08 GXP SO i have the single bolt cam gear. Do we have to replace the lifters. IM assuiming that might depend on the cam. Hotter the cam more we would want/need different lifters
Old Mar 1, 2009 | 01:31 AM
CenTexSS's Avatar
I wouldn't go to too hot of a cam, with our long *** gears it might end up hurting the powerband.
Old Mar 1, 2009 | 09:45 AM
GXPRIX27's Avatar
this thread will be quite usefull for me too, wanting to cam my 08 gxp also
Old Mar 1, 2009 | 09:26 PM
Sittingmongoose's Avatar
correct me if i am wrong but no one has actually seen a positive change by putting in a cam in our ls4's on this forum at least
Old Mar 1, 2009 | 10:19 PM
neilownz's Avatar
that sounds accurate, but nobody that ive seen on here has really pumped up the engine displacement past 5.3l. too bad that it would cost so much to make it happen.
Old Mar 1, 2009 | 10:20 PM
Panther427's Avatar
Well a good cam should help but would love to see Some positive feedback from thouse who have done it
Old Mar 4, 2009 | 10:05 PM
phat_ridegt's Avatar
we cammed our 07 gxp w/ the ls1 hot cam. the car lost a good amount of low end power, but gained it all back, and then some up top. we'll be putting 3.29 gears this weekend i believe.
if you change the lifters, you'll need ls2 style lifter trays too
Old Mar 5, 2009 | 12:42 AM
Panther427's Avatar
Thanks. how much did all the suporting items cost.
Old Mar 5, 2009 | 12:53 AM
Red 01SS's Avatar
Why would you need to change lifters?
I can see pushrods, springs, retainers, tune, etc...
Old Mar 5, 2009 | 12:57 AM
Panther427's Avatar
If u change lifters you disable DOD. As they are a major part of the system. From what i have herd the factory lifters have there limits as far as lift goes. Plus When running in DODmode on aka V4 car would run rough.. possibly enough to cause damage(just a possiblity) But that would be with a serious cam.
Also i was thinking we could just swap in a L76 6.0L block as it has the provisions for DOD. Buy a block swap all the rest of the parts over LOL>
Old Mar 5, 2009 | 01:42 AM
Red 01SS's Avatar
Honestly, if you are talking about high HP, I wouldn't worry about DOD.
Old Mar 5, 2009 | 01:57 AM
Panther427's Avatar
That is true. Kinda wanna see how much power i can push with DOD still active. Probally just go with Different ration roller rockers for now. but still a good thread.
Old Mar 5, 2009 | 10:33 AM
ChefChub's Avatar
If you want high power plus dod go with a turbo.
Old Mar 6, 2009 | 07:46 AM
Brian396's Avatar
I'll 2nd that
Old Mar 6, 2009 | 08:17 AM
Panther427's Avatar
Turbos cost to much at this point in the game. and after looking over the install manuel for cartunning i do not like there kit
Old Mar 6, 2009 | 09:19 AM
Bryan921SS's Avatar
What don't you like about their kit?? The biggest draw backs are the use of the standard exhaust manifolds.
Old Mar 6, 2009 | 10:39 AM
06 SS's Avatar
All the LS4 cars come with 3.29 final drive already. The chain drive drops that down to the 2.93 effective ratio. Might want to hold off replacing one gear set with an identical one...
