Please Help!!n p0521 Code
Old Feb 13, 2011 | 09:16 PM
  #41
Hawkins04's Avatar
everything looks fine oil is at the right level. anyone know what I should do?
Old Mar 5, 2011 | 02:32 PM
  #42
BuffaloSS's Avatar
I started getting p0521 last week and thanks to you all I didn't panic. However, since it seemed like a benign issue, I ignored it until yesterday when I had the red Oil Pressure light came on with a Low Pressure/Stop Engine message on the DIC. I spent the $40 on the sensor and another $10 on the special socket (was recommended instead of the 27mm
Old Mar 5, 2011 | 02:35 PM
  #43
BuffaloSS's Avatar
I started getting p0521 last week and thanks to you all I didn't panic. However, since it seemed like a benign issue, I ignored it until yesterday when I had the red Oil Pressure light came on with a Low Pressure/Stop Engine message on the DIC. I spent the $40 on the sensor and another $10 on the special socket (was recommended instead of the 27mm....neither of which I had anyway). Swapped out the sensor in the AutoZone lot in less than 5min.
Thanks guys! Couldn't have been easier, unless it purchased and replaced itself.
Old Mar 5, 2011 | 02:39 PM
  #44
BuffaloSS's Avatar
Ooops...stupid phone app causing the double post.
Anyway...just wanted to let those w tuners know that when I hooked up the Diablo, Oil Pressure read 91.77% at idle, and dropped instantly to 0% with any acceleration. With the new sensor, it fluctuates with rpms
Old Mar 5, 2011 | 04:16 PM
  #45
Kazmaniac's Avatar
Glad someone saved some $$$ on the part!
Old Mar 8, 2011 | 05:49 PM
  #46
KMKGXP06's Avatar
Hawkins04,
Any luck with your code problems? My code just tripped on Sunday P0521. I won't have the chance to take it to the shop until the weekend, so I've been driving around with the HVAC and volume to the stereo off... paranoid that Im going to start hearing some bad noises coming from the engine bay. I could replace the sensor here but I want to let the mechanic hook up a pressure gage to make sure im ok.
Im also getting a sloshing water noise when I hit the accelerator, but thats probably air in the radiator lines.
Kind of odd that everyone who wrote about this problem owns a 2006 and all of the problems started to surface within a few month period.
Old May 16, 2011 | 10:50 PM
  #47
hazards280's Avatar
Originally Posted by KMKGXP06
Hawkins04,
Okay guys, I really need help.
I own a 05 GXP and am experiencing the same problems. I replaced the defective one with a new OEM one and the code is still tripping. What else could be causing the problem? Any ideas. The dealership is ready to screw me over tomorrow when I take it in to be repaired. I can feel it. They are telling me its the BCM and Wiring harness and a whole bunch of ****.
It has to be something minute.
Old May 17, 2011 | 07:35 AM
  #48
CubSmurf's Avatar
Does the 05 GXP's have DoD? If that is working, the part worked. Mine started working right away, but had to take it to an auto parts place to clear the code. MIGHT be all you need to do.
Old May 17, 2011 | 03:09 PM
  #49
hazards280's Avatar
They do have DOD. It works until the code comes back up and then it disables itself. It take about 5 minutes after clearing for the code to reappear.
Old May 17, 2011 | 03:22 PM
  #50
CubSmurf's Avatar
Well that sucks....I honestly don't have any other suggestions...
My issue cleared up with the new sensor. Anyone else have suggestions for 'hazards'?
Old May 30, 2011 | 02:39 AM
  #51
swiftx19's Avatar
Default quick question
just a quick question. im getting the code on my monte and i was just wondering if it will harm the engine without an immediate fix. cause right now money is tight.
i appreciate any advice.
Old May 30, 2011 | 06:31 AM
  #52
94ss06gxp's Avatar
your DOD will be disengaged but other than that no, just make sure your not actually low on oil pressure
Old May 30, 2011 | 06:34 AM
  #53
hazards280's Avatar
Haha, Right!
94ss06gxp: Engine should be done today man! If that is the case it would have taken us about three days for the complete swap.
Old Jan 22, 2013 | 08:52 AM
  #54
blkchevyz's Avatar
i know this is old, but figured its better than starting a new thread on the same subject.
mines throwing that code as well, i was wanting to test my oil pressure before just ordering a sensor... how do you test it? my gm manual says i need a special adapter that screws in place of the oil filter... was hoping there was an easier way.
Old Jan 22, 2013 | 11:35 AM
  #55
blkchevyz's Avatar
also is our a switch or a sensors? autozone keeps pulling up a 15 dollar switch, and i'm thinking that not correct, orilys shows 55 dollar sensor.
