Adding "Tap Shift" to my Mote
Old Apr 7, 2009 | 11:40 AM
LS4 swap's Avatar
Question Adding "Tap Shift" to my Mote
I have a Monte drive train that is in my Fiero. I want to add Tap Shift and want to know if it is possable to do with out the special Tap Shift tranny from the GXP?
Old Apr 7, 2009 | 12:35 PM
Mgpeagle's Avatar
You need a special valve body that only the Comp.-G and GXP have. I am not too sure if the Monte/Impala has that valve body or not.
-Mike
Old Apr 7, 2009 | 12:58 PM
06MonteSS's Avatar
LS1Tech Sponsor
http://www.retrotekspeed.com/product...th-f1-paddles/
and here's an article about doing an actual install:
http://www.superchevy.com/technical/...ers/index.html
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Apr 7, 2009 | 01:19 PM
LS4 swap's Avatar
Thanks for the info on the shifters, but I have a steering wheel from the Malibu LTZ/Vette C-6 with the shifters. They are compatable with the GXP(atleast they have the same resistor values that the TMC needs to see for the upshift and down shift). So I am good on that side of the project. I will just hook it up and see what happens if there are no mechanical limitations to it?
Old Apr 7, 2009 | 03:34 PM
Honey Badger's Avatar
You'll need a Comp-G or GXP PCM and tranny in order to make it function like it should. They are tuned differently and the wiring is different in them from a traditional, but if you have the GXP driveline you should be alright, but you'll need a PCM to make it work.
