Anyone have a "How to..." to check for a dead lifter?
As many have seen me post before, I have a "rocks in a can" chatter that occurs only when in 4-cyl mode, and only noticeable when driving in the city (where the sound can bounce off the surrounding cars & buildings). It stops IMMEDIATELY when I slow down enough to let the car kick back into 8-cyl mode.
Given that, would it be one of the DoD lifters, or one of the non-DoD lifters? Which cylinders have which?
I have never taken apart my/an engine, and would like to NOT ***k it up in doing so, so a write-up or basic how-to would be most helpful. Thanks!
https://ls1tech.com/forums/5322427-post3.html
https://ls1tech.com/forums/5322481-post4.html
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
With that, anyone know if it would make more sense for the noise to be coming from a DoD lifter, or the others? Having never seen a DoD lifter, I cannot tell if the two-piece design could be the culprit? Rattling around as the cam hits it on every turn when in 4-cyl mode?
Also, if the lifter failed completely, wouldn't that cause some other condition that enabled a CEL?
I don't know how to check a lifter still in the engine. Checking one outside the engine can be done by using a drill press with a push rod mounted in it pushing down on the lifter in a container of oil, timing how long it takes to compress the lifter. A dead lifter goes down faster than the rest. I couldn't begin to tell you how one of the DOD lifters could be checked, but I do have a drawing I found on the net somewhat showing the DOD lifters. Don't know where I got it from.
I stopped buying those long ago, they only have very basic info, and nothing is relevant.
Buff - I thought Badd post some pics during his cam swap. Changing out a lifter is a good days work on these cars. Camshaft you would want the weekend.
Maybe go after rockers when you have it apart.
hahahaha
