Need help asap please!!!!!!!!!!
Old Apr 24, 2009 | 06:15 PM
bugzy530's Avatar
Default Need help asap please!!!!!!!!!!
CAN SOMEONE TELL ME WHAT THE HELL THEY USED TO FLIP THIS MOTOR MOUNT I ALREADY BROKE a pair of plyers tryin to do this PPPLLEEAASSSEREE HOW EXACTLY DDID YOU FLIP THIS MOUNT I AM IN THE PROCESS OF DOIN THIS NOW AND AM STUCK
Old Apr 24, 2009 | 06:18 PM
JP_GXP's Avatar
WD-40 and two wrenches
Old Apr 24, 2009 | 06:27 PM
JC05GXP's Avatar
try this http://www.clubgp.com/newforum/tm.as...de=&s=#2110673
Old Apr 24, 2009 | 08:03 PM
Panther427's Avatar
Just ran out side to do this after seeing what needed done. I took a screw driver to pry the rubber from the metal housing then sprayed the lube just on the front and back of the mount. Put the Bolt back in, tighted down. used the my socket and ratchet to flip the mount. nice and easy.
Old Apr 24, 2009 | 10:49 PM
williamGT's Avatar
did you notice the difference?.....I will be doing this on my days off if its nice out.
Old Apr 25, 2009 | 02:24 AM
Panther427's Avatar
Ya.For the most part it tamed the t/q steer on a good smooth street. Shifts are not as violent since the hole motor and trans arent moving as much, almost feels like it shifts faster
Old Apr 25, 2009 | 08:12 AM
06MonteSS's Avatar
LS1Tech Sponsor
yup, you'll notice a difference... gets the power to the wheels faster cuz there's less flex...
even better, I just removed that whole rubber one and put in a poly mount altogether...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Apr 25, 2009 | 12:06 PM
Panther427's Avatar
mine flipped really eaisly, i was surprised
Old Apr 25, 2009 | 02:31 PM
neilownz's Avatar
Lube it good. Use a narrow screwdriver/awl to pry it away and spray some wd in there all around. It was a bitch to cut mine out when I replaced it with a poly one. That damn hump in the middle!@
Old Apr 25, 2009 | 10:13 PM
Bryan921SS's Avatar
I am sorry, and I know full well I will be coming off as a dick...but I can't hold my tongue....how are you guys having trouble doing this???
Can of WD-40, a box wrench, and a socked wrench....5 minutes of your time, and you are done...
Old Apr 26, 2009 | 03:53 PM
07carlocrusader's Avatar
I know we talked about this before but,...
Any vibration lately and/or before??
Old Apr 26, 2009 | 04:07 PM
06 SS's Avatar
I can turn a fairly decent wrench and I struggled with it for almost 30 minutes. Two box wrenches, lube, and a two cheater bars. Mine did not want to cooperate at all.
Old Apr 26, 2009 | 05:49 PM
LS4SPEED's Avatar
Shoot mine turned easy as pie, but it only had 5K miles on it when I did it!
Old Apr 26, 2009 | 11:46 PM
Heslekrants's Avatar
Mine was a 5 minute job as well but i did mine at 9k miles. With 50K miles on yours you may need to soak it for awhile. It needs to be lubed really good to turn.
Old Apr 27, 2009 | 09:36 AM
beznich's Avatar
Mine took 15 minutes, 5 minutes to flip the sucker, and 10 minutes of beer drinking.
Old Apr 27, 2009 | 12:35 PM
Panther427's Avatar
I did mine at 29K and it was easy.
Old Apr 27, 2009 | 04:46 PM
bugzy530's Avatar
I just want to say thanks for the people who did and for whoever jus replied be it a positive comment or not i got the job done finally and it does make a big difference thanks again.
Old Apr 27, 2009 | 04:51 PM
beznich's Avatar
Glad to hear you got it done. What's next?
Old Apr 27, 2009 | 05:52 PM
06 SS's Avatar
Mine was done at around 5K miles as I recall. My driveway has more than a slight incline to it, maybe it had more shear force on it that on a flat. I would not think it would increase the friction that much, but maybe it did.
Old Apr 28, 2009 | 04:57 PM
bugzy530's Avatar
man i dont even knw do u have any suggestions, besides whats already on my signature?????
