Head
Old May 21, 2009 | 09:55 AM
07SS's Avatar
Default Head
While I was running the nitrous the spark plug in the #7 cylinder broke and the part of the spark plug that broke went through my exhaust valve. It damaged the head pretty bad as well. Does anyone know where I can get a replacement head? I have tried a few places and no one seems to have it.
Old May 21, 2009 | 11:08 AM
Bryan921SS's Avatar
Get the 5.3 stage 2.5 heads...upgrade for more power...other wise i think we are a normal LS6 243 casting...not sure though
Old May 21, 2009 | 11:16 AM
RickAKATed10's Avatar
The thread title confused me... Carry on!
Old May 21, 2009 | 11:30 AM
Panther427's Avatar
I will see if there is any 243 heads around my parts.
Old May 21, 2009 | 12:02 PM
Pauls325's Avatar
wow nitrous guys are having problems huh
Old May 21, 2009 | 12:10 PM
Mels SS's Avatar
If they are using a dry shot thats the problem. On these motors only use a wet shot
Old May 21, 2009 | 12:19 PM
Panther427's Avatar
Ya but rosko was using wet shot i thought. number seven is a bitch. My buddy with his GTO had Number seven hole go twice with a chipped piston in a month
Old May 21, 2009 | 12:26 PM
TheMonteMan's Avatar
in the parts classified section there was a couple 243s for sale.
Old May 21, 2009 | 01:25 PM
TiredGXP's Avatar
You might want to research valve sizes if you're changing heads. The 243 heads on the LS4 have smaller valves than many of the LS1/2/6 heads out there. Probably has something to do with a 96mm bore instead of the 99mm LS1/6 bore.
I don't recall any threads that specifically discussed running heads with larger valves.
Old May 21, 2009 | 02:25 PM
Sittingmongoose's Avatar
i know that there is a junk yard by me with a gxp, you can prolly pull the heads off that ones. The website is http://www.alsautopa.com/index.html call them and they might have one cheap for you. maybe they can ship you it.
Old May 21, 2009 | 10:31 PM
CenTexSS's Avatar
I wonder if it's something in the intake manifold causing cylinder 7 to go lean while spraying. Maybe the distribution of air in the runners is not getting enough to cyl 7
Old May 21, 2009 | 11:24 PM
Panther427's Avatar
well there is the large obstruction in the opeing could be directing air away from number seven.
Old May 22, 2009 | 01:29 AM
StealthV8's Avatar
I believe they both were using wet shots
Old May 22, 2009 | 08:51 AM
tokay57's Avatar
woudn't that cause a rich condition, too much fuel per given air/nitrous mix.
Old May 22, 2009 | 10:59 AM
Panther427's Avatar
Ya maybe number 6 and 8 are rich while 7 goes lean
Old May 22, 2009 | 11:26 AM
07SS's Avatar
thanks for your help guys. I found a head and if all goes as planned the car should be running again by the end of this weekend. Yeah, I was running a wet shot. Do you guys think there is a chance that other cylinders were damaged and I could run into some issues down the road? I did a compression check on the other cylinders and everything looks fine, but I didn't take the other head off and take a look at the valves on the right head.
Old May 22, 2009 | 02:43 PM
supercatxr7's Avatar
Just curious what did your compression check show for psi?
Old May 22, 2009 | 04:12 PM
radorider03's Avatar
You might want to pull that other head and check it out just to be safe. Its a long weekend anyway tons of fun. Let us know whats going on with the nitrous I want to spray mine too.
Old May 23, 2009 | 06:56 AM
TurboMatt's Avatar
As long as none of the other plugs are broken or melted, and the pistons that are currently visible look okay, then I wouldn't bother pulling the other head. Sounds like you've got enough to do already.
- Matt
