wheel question
Old Jun 13, 2009 | 05:34 PM
08silverimpyss's Avatar
Default wheel question
wheel question for ya guys. does anyone happen to know if therre are any 10 inch wide wheels that will fit an 08 impala ss. i was lookin for wider wheels so i can put some drag radials on for when i got to the track. thansk
Old Jun 13, 2009 | 05:54 PM
CenTexSS's Avatar
What size drag radials are you planning to run?
I'm wanting to use a 255/50/16 on stock Grand Prix wheels, I've seen a member with a MCSS with that set up on here.
Old Jun 13, 2009 | 05:56 PM
i was lookin at puttin somethin lik 275/35/18's on. i was looking at the bfgoodrich streetable drag radials, and i liked em haha.
Old Jun 13, 2009 | 06:00 PM
CenTexSS's Avatar
Are you heavily modded? That much tire might be a little much.
Mixerda on this site ran 245/45/18 Mickey Thomson DR's with no traction issues.
*edit*
I have 18x8.5" ASA JH8's which run about $100 each from tire rack. It should be able to handle a 275mm tire.
Old Jun 13, 2009 | 07:33 PM
neilownz's Avatar
A 16 would make for some worse handling I would assume.
Old Jun 14, 2009 | 01:00 AM
CenTexSS's Avatar
I highly doubt handling is of any consideration, since he's wanting to run drag radials. Not to mention a 50 series sidewall > 35 series for drag racing.
Old Jun 14, 2009 | 06:40 AM
Corny40's Avatar
I seriously doubt you'd be able to get a 10" wheel to fit our cars.
Well, it might fit, but don't plan on driving the car.
Old Jun 14, 2009 | 01:13 PM
ya that was my main worry haha. do the asa jh8s, the 8.5 inch wide ones fit fine, or is there rub?
Old Jun 14, 2009 | 01:55 PM
CenTexSS's Avatar
I don't rub with mine, but I'm running OEM size tires.
Edit. Rossko is running 275/40/18's on the front of his GXP with no rubbing, but the GXP's seems to have wider fenders.
