We need to brainstorm...Trans. heat...
I'd love to post pics but that will be very hard. I have one cooler in front of one fan and one in front of the other fan. If I can get my hands on a camera I'll take some pics.
All I can say is it worked like a charm.
-Mike
Nothing over 200. 199 from the drive home which is close to an hour. That was the highest temp. When it hits 150 it takes forever to go up. I certainly do not expect the high temps I was getting. With just the radiator cooler I was sseing 244 as a high on a consistant basis. With a cooler running in series with the radiator I was seeing 235 as a high on a consistant basis. With just one cooler hooked up bypassing the radiator I was seeing 228 as a high on a hot day but only once in a while. With both coolers hooked up the highest I have seen is 199. It is good for a 45 degree drop in temps which will make the trans last a lot longer. So far I am glad I did this. The experiment so far succeeded.
-Mike
http://shop.advanceautoparts.com/web...GRPCOOLAMS____
-Mike
