rockers???
Old Jul 10, 2009 | 06:02 PM
1 CLEAN SUP3R SPORT's Avatar
Originally Posted by davidgxp
i'm using crane gold race rockers with ls6 springs and the power gain is amazing! The car idles much better and no longer has a 1-2 lag. I just need to get retuned and adjust my shift points to about 6200 or so. I got really lucky with the rockers, i put them on adjusted them once and haven't had a single problem yet. Don't use cranes instructions!
what did you pay for the set of rockers and springs???did you buy on line or automotive store...
Old Jul 13, 2009 | 08:47 PM
DavidGXP's Avatar
Sorry for the late reply! I bought the rocker kit used on E bay for 400.00 and the springs from Lingenfelter for 75.00. I used the "Tims Tool" found in the for-sale section of this forum for 55.00 with the air compressor attachment. Still no ticks and vacuum is 18-19"hg at idle in drive. Now Im working on fitting an intake manifold with a LS2 valley tray. I just need to make a throttle body adapter and re route some fittings.
Old Jul 13, 2009 | 09:09 PM
AlabamaGuy's Avatar
Bump for interest on the intake manifold
Old Jul 13, 2009 | 09:46 PM
DavidGXP's Avatar
If this everything works out I'll do a write up. Right now it's going to be few weeks. Patience is the key!
Old Jul 13, 2009 | 09:59 PM
So you bought them used,what did you look for when you bought them used?? Meaning how did you know you were getting a good used set of rockers?? Would be wroth it to save a hundo or so for sum used??
And very interested in the intake manifold as well,please update....
Old Jul 13, 2009 | 10:27 PM
DavidGXP's Avatar
Well just like everything on E bay I took a chance and lucky for me I got lucky. It was a very easy kit to install and the results were extremely rewarding. Roller rockers, and push rods don't really wear, it's the studs and the poly locks that take a beating if there constantly being loosened and re tight-ed. If you can find a used set, go for it, or else keep saving. Either way you won't be disappointed!
I don't wanna hype.. the intake install up just yet cause I haven't started the install. once I get it on, I'll be sure to let everyone know what I did to get it on, and running. Here's the low down... LS6 Intake, injectors, fuel rails and LS2/3 valley cover. I'm going to use the LS4 throttle body with an adapter. The map sensor will be relocated and the rear vacuum fittings on the LS6 intake will be removed and the hole plugged for power steering pump clearance. Right now I'm waiting on the Valley cover and once I get it the crank case breather will be removed and the hole will be welded shut. The oil pressure outlet will be modified too. I will need to do some tuning if I get it to work, since I'll have bigger injectors and no more DOD solenoids. Stay tuned!
Old Jul 13, 2009 | 11:30 PM
TheMonteMan's Avatar
hells yes!!!! hope someone gets that **** to work
Old Aug 17, 2009 | 11:28 AM
otherwisebusy's Avatar
Withthe SLP rockers, how necessary are the reccommended springs, etc
NOTE 2: LS1, LS6 and LS2 engines may require SLP part # 53002 or part # 53003 springs, part # 53103 or part # 53104 retainers and part # 66345 keepers. Please reference chart below for proper application and part # 51185 or part # 51186 rocker arm package when purchasing the complete package.
If they are necessary, which ones do I order for the LS4?
Old Aug 17, 2009 | 11:56 AM
Mgpeagle's Avatar
I didn't change the springs on mine. I just used oil restricted pushrods. I have no valve float. Everything works great and no ticking from the rockers.
-Mike
Old Aug 17, 2009 | 02:18 PM
So you just ordered the rockers? Where did you get the pushrods? Do the pushrods have any affect on the DoD? It may be a stupid question but I am not mechanically savy as some.
Old Aug 17, 2009 | 03:48 PM
Mgpeagle's Avatar
I found the rockers in the classifieds for a steal on this board. They are SLP's and have 9k on them when I purchased them. The pushrods I used are Intense's Oil Restricted ones. Here is the link:
http://intense-racing.com/Merchant2/...LSx_Valvetrain
Great combo so far. I have about 1000 miles on the rockers since install. Absolutely no problems. I also kept stock wide open throttle shift points.
-Mike
Old Aug 20, 2009 | 10:47 PM
  #32
beznich's Avatar
b u m p
