Going Catless, tune Question
Old Jul 7, 2009 | 09:23 PM
AlabamaGuy's Avatar
Default Going Catless, tune Question
I know that it's necessary to tune out the rear O2 sensor. My question is how long can you safely run without it? Would it be ok to drive the car 100 miles to the dyno? I'm assuming this is just an O2 check sensor and not one that regulates A/F since it can be tuned out. Thoughts?
Old Jul 7, 2009 | 09:26 PM
Panther427's Avatar
Its there to verify that the Cat is working. Dropping emmions level to the correct level. There should be no problems driving to the dyno.
Old Jul 7, 2009 | 09:32 PM
AlabamaGuy's Avatar
Great, so basically it causes a CEL...does it pull timing at all?
Old Jul 7, 2009 | 09:55 PM
okie123's Avatar
It will eventually cause a CEL. Its trouble code will be unchecked to trip a cel. Its there for looks only at that point.
Old Jul 7, 2009 | 11:26 PM
Nacho SS's Avatar
Its just a light, no problems occur that change tuning/power output.
Old Jul 8, 2009 | 09:11 AM
JP_GXP's Avatar
I've been catless for a few months now, the light gets a little annoying, but everything else is fine.
EDIT: Remote Start stops working though... It'll come back if you get the code tuned out.
Old Jul 8, 2009 | 11:20 AM
06MonteSS's Avatar
LS1Tech Sponsor
yeah, besides the rear O2 codes, you also have to disable the CAT codes... P0420 and P0430... and also turn off the COT protection in the tune as well, since you don't have the cats anyway...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jul 9, 2009 | 04:49 AM
StealthV8's Avatar
so if you disable the codes do you even need to weld in a bung for the second 02 sensor?
Old Jul 9, 2009 | 05:07 PM
Brian396's Avatar
Nope.
Old Jul 9, 2009 | 05:16 PM
06 SS's Avatar
if you are going to go without a cat-con, for off road use only, of course, you can tune out the cat-con over-temp protection. It essentially richens the mixture over a certain engine speed/load to keep the temps down in the cat-con. Lowers mileage and completely unnecessary if there is no cc.
