Upgrading Spark Plug Wires
Old Dec 11, 2010 | 09:00 PM
Shev's Avatar
seems like there has to be some advantages to swapping to certain aftermarket plugs. What abaout Granatelli (?), with such a low ohm resistance it seems like more effeciency is certain, even if it is just the slightest difference. better ignition meens better efficiency unless you have bad plugs, packs, or timing off.
Old Dec 11, 2010 | 09:50 PM
smokin06impala ss's Avatar
Originally Posted by RedHotG8
Aftermarket wires won't give you any more power so you're better off using the stock wires. Same goes for plugs, unless you are putting out a lot of horsepower.
Yeah I'm aware that there is no horsepower difference just like the way they would look giving the engine a more aggressive look with those thick wires
Old Dec 12, 2010 | 10:48 PM
supercatxr7's Avatar
Originally Posted by DP 08 GXP
he is correct...save your money and stay with OEM
Agreed!
Old Dec 15, 2010 | 09:32 AM
jim_tucker's Avatar
Nology hot wires, each plug wire has its own capacitor but there not cheap
Old Dec 17, 2010 | 01:15 PM
BLNLS1/RX7's Avatar
Originally Posted by neilownz
I have taylor ones for my car and truck. Thundervolt 50s (part 98005) and Pro 409s (part 79205 for red and 79605 for blue). They ran like 70-80 a set from an online vender.
This is what I run and I ordered them from Summit.
