plans for august
Old Jul 27, 2009 | 06:18 AM
StealthV8's Avatar
Originally Posted by Brian396
Holy crap you guys are crazy. How could you do that to a family car?
don't you have a tubro? lol
Old Jul 27, 2009 | 07:33 AM
Brian396's Avatar
Yeah, but that’s just a bolt on.
Old Jul 27, 2009 | 08:21 AM
DavidGXP's Avatar
rear seat delete has been made i still have a few finishing touches to do but its installed. i ended up using 1/8" plywood and glued some gray carpet over it. looks pretty good. i bolted it place using the stock hardware from the stock upper seat and the lower portion is hinged. the edges are a little rough so im going to round the edges. saved maybe 25lbs? the stock upper seat with the frame is pretty heavy and the lower seat is light. i can put my stock seat back in, in about 10 mins. like i said i won't do anything that i can't reverse i will not cut this car up. hit 0-60 in 5.22 sec. last night with a 1/4 tank of gas and bald front tires.
Old Jul 27, 2009 | 04:36 PM
Sittingmongoose's Avatar
Originally Posted by DavidGXP
did you really remove the ac? if true then what is your belt orintation like or how did you route everthing after pulling the compressor?
really?
Old Jul 27, 2009 | 04:50 PM
DavidGXP's Avatar
Originally Posted by Sittingmongoose
really?
doh....!
Old Jul 27, 2009 | 05:05 PM
Pauls325's Avatar
the trick is to practice launching a lot although my transmission has been feeling rather clunky lately..... im sure ill need a new one before warrenty is up
