plans for august
Old Jul 25, 2009 | 10:01 AM
DavidGXP's Avatar
Default plans for august
Well Ia m going to be pretty broke for a bit, but Im not going to let money stop me from modding. car is a beast right now and i find my self drifting off through oit the days thinking about what i can do to my car. well im going to remove some weightstarting with the interior. im ging to pull out the carpet and sound deading mat and replace with light weight carprt im also going to install a rear seat delete made out of corrugated fiber board and black carpet since i dont use my back seats i have no need for them. i built a throttle body heat, and maf heatshield last week from aluminum and they work great. it takes the iat sender a long time to heat up now and the throttle body stays pretty cool untail the intake gets hot. i need to wrap my fuel line going form the tank to intake cause that sucker gets hot. does anybody know how much the stock front seats weigh? i found some killer racing seats for dirt cheap and am thinking about using them but they weigh 32 lbs a piece. need to buy a camera....
Old Jul 25, 2009 | 10:04 AM
DavidGXP's Avatar
excuse the bad spelling and grammer im using my phone and im at work.
Old Jul 25, 2009 | 11:17 AM
Panther427's Avatar
Sounds like you have some serious plans.
Old Jul 25, 2009 | 11:42 AM
Pauls325's Avatar
nice i dont know how much our seats weigh but we have a toyota sienna with leather seats in the middle that are removable i just weighed one and it was fifty lb ours being power and heated are easily 55 i would say
im looking to buy some kirkeys i would probably have to fab some brackets but being ony 11 lbs each losing 70lb could be huge
oh yeah if you could weigh the back seats that would be great
Old Jul 25, 2009 | 11:59 AM
DavidGXP's Avatar
kirkys might be a little uncomfortable but would deffinitely save some serrious weight. i wonder how hard it would be to remove the a/c compressior and stuff from under the hood? i never use my a/c so im just storing junk. it would be nice to remove it and keep everything stored away. i really dont mind taking stuff of as long as i can put everything back on. i don't wanna hack this car up or ruien anything
Old Jul 25, 2009 | 11:14 PM
Pauls325's Avatar
thats how i am i still have the orig painted hood and the headlight in case i ever need to go back totally stock the cutout is welded in though
Old Jul 26, 2009 | 12:18 AM
StealthV8's Avatar
my trunk is down to the painted metal and my rear seats are gone, you will not believe how much better you will be able to launch. The sweet spot when you get traction will come much sooner.
Old Jul 26, 2009 | 12:20 AM
StealthV8's Avatar
i was also thinking about taking all the A/C stuff and fans etc out
Old Jul 26, 2009 | 09:17 AM
Pauls325's Avatar
yeah i took all the carpet and **** our right away when i got the car i was thinking about losing the sound deadening in the trunk what did you do to remove that?
Old Jul 26, 2009 | 10:32 AM
DavidGXP's Avatar
use a heat gun or a propane tourch and a scraper. recoat th floor with a little bit of truck bed liner (hurculiner) to seal up plugs and seams or welds if the deadner was covering that stuff up i might just line my whole trunk.
Old Jul 26, 2009 | 10:43 AM
Pauls325's Avatar
where can you buy that stuff at ? how much weight do you think you saved by removing the deadening
Old Jul 26, 2009 | 12:20 PM
DavidGXP's Avatar
havent done anything yet but i will be in a few weeks got stuck watching the kid today so i cant do much but play madden 09. im shooting for 50 lbs with the rear seat delete and lighter carpet im going to gut the trunk too so maybe 60? it all adds upright? car will still be safe, just louder. on my cutlass removing the deadner took out 25lbs i left the trunk stock so that stuff is pretty heavy. once i go with diffrent seats im sure i will removed at least 100 and if i can figure out how to remove the a/c then i should be around 150. i will have to figure out how to re route the belt or use a custom made pulley with a bracket that bolts in place of the compressior. tracking? no rome to work on this car though so i dont knowbif i can get my idea to work. im really all for pulling the?dam ac radiator out cause its right in front of the radiator so id get better airflow/better cooling. i'll be sure to weigh everything on our big scale at work and post the resaults. has anyone else removed some weight from your ca
Old Jul 26, 2009 | 12:23 PM
StealthV8's Avatar
I didn't have to use a heat gun to remove anything, just ripped it out. All the welds are painted in the trunk so no need for anything else, paint adds weight too lol.. And our front seats are very...very heavy too, i'm replacing with lightweight racing seats.
Old Jul 26, 2009 | 12:27 PM
StealthV8's Avatar
I'm hoping we can get by with running a shorter belt and not running a dumby pulley with the ac pulley out, so there is less drag there too
Old Jul 26, 2009 | 12:28 PM
DavidGXP's Avatar
5.1 is moving paul i guess i'll keep practicing my springs and rockers took me from 5.7 to 5.4 im sure it will do better once i raise my shift points to 6200 right now im at 5900 and after going into second i can tell it shifted to early.
Old Jul 26, 2009 | 12:41 PM
Brian396's Avatar
Holy crap you guys are crazy. How could you do that to a family car?
Old Jul 26, 2009 | 03:58 PM
Sittingmongoose's Avatar
i took, all the carpet and seats out of my car, along with the ac, I lost 175lbs. Car was much faster but i wanted more weight reduction so i removed the wheels and engine too. Something didnt work out well though cause now it wont move.
Old Jul 26, 2009 | 05:05 PM
CenTexSS's Avatar
That's what I'm thinking. I couldn't do it to something as new as our cars. Maybe an older car built for drag or something.
Old Jul 26, 2009 | 10:53 PM
DavidGXP's Avatar
did you really remove the ac? if true then what is your belt orintation like or how did you route everthing after pulling the compressor?
Old Jul 26, 2009 | 11:48 PM
AlabamaGuy's Avatar
I couldn't do this to my car...maybe in 15 years but.....dang
