What would cause noisy lifters when cold?
If a lifter swap is necessary then what is invovled? I've done some H/C installs on friends LSX trucks/cars but never a DOD LS4. Any help is appreciated!!!
Second they are dirty beasts inside, The burnt varnish builds up a thin layer on everything internal, especially if your tail pipes are black inside due to incorrect fueling.
There is a DOD filter located underneath the oil pressure sensor, next to the TB neck, (P/N 12585328 ten bucks in Canada, probably two bucks for you guys south)
I use http://www.duralube.com/Galleries/Sm...-SellSheet.pdf put 1 in now and one every oil change. It works and I have used it for many,many years.
On their home page there is even a savings coupon now. Their upper cyl. lubricant works also.
-Mike
