LS2 Valley Cover - DOD delete
Old Sep 3, 2009 | 03:41 PM
supercatxr7's Avatar
Default LS2 Valley Cover - DOD delete
Anyone know if the LS2 valley cover will bolt up to our block? Thinking of deleting DOD all together.
http://www.g8board.com/forums/showthread.php?t=19612
thanks!
Old Sep 3, 2009 | 04:43 PM
Brian396's Avatar
Yes it will bolt right on.
Old Sep 3, 2009 | 05:09 PM
JP_GXP's Avatar
I wish it was 'that easy' to change the cam on our engines...
Old Sep 4, 2009 | 08:04 PM
Is the oil pressure sender in the same location on the LS2 valley cover? I'm thinking if it is and I cut it off and angle it out of the way with some welding, the LS6 manifold will go on and a throttle body.
Old Sep 4, 2009 | 09:46 PM
Brian396's Avatar
The oil pressure sender is in the same location. Have you considered a plug with lock tight, and then grind the corner off. Then relocate the sending unit to the side of the block.
