Water Pump - How hard to DIY?
First off...will stop-leak stop this kind of leak? I'm not certain where it's coming from, and can see that the pump is a little wet in different areas. It's possible that it's a hose, too, but again...not sure.
If some stop-leak product isn't going to work, how hard is it to R&R the WP? Does the engine need to be hoisted up or dropped down? I could not possibly do that myself, nor can I afford a $1000 repair bill.
Surprisingly, the ACDelco replacement WP is only $120 from RockAuto, plus w/e gasket(s) I need (have no idea), and shipping...so likely $180 or so.
failly easy once you take out the battery, tray and headlight .u got 5 screw and ur done.. just ply the old one out once all the screws are out make sure the old gaskets completely removed and sealed bak up.and your good to go.
pretty easy go for it. save your self couple hundred by doin it yourself in about two hours tops..
EDIT: Also, since I will be dumping the coolant anyway, is it OK to at least try the stop leak stuff?
Lastly, which "stop leak" product would you recommend? The only one that comes to mind is Bar's.
And GM sure did use a leak preventer. It came in my STS with the N*.
