cammed gxp now has an LS2 intake!
Old Jan 26, 2010 | 06:09 PM
willybuck's Avatar
how is the driving and gas millage without the DOD and with the cam and intake
Old Jan 26, 2010 | 06:55 PM
phat_ridegt's Avatar
the intake REALLY opened the car up, and not having DOD makes it respond better while cruising
fuel mileage isnt terrible...17-22
Old Jan 26, 2010 | 08:26 PM
willybuck's Avatar
what kind of times with it
Old Jan 28, 2010 | 08:32 PM
teamfbody's Avatar
i just have 1 word 4 this swap...................IMPRESSIVE!!!!!!!!!!!!!!!!! !!!!
Old Jan 28, 2010 | 09:10 PM
Rossko85's Avatar
Keep it up guys...we'll get her there....lol
Old May 14, 2010 | 06:12 AM
LSXFiero's Avatar
Any updates?
Old May 14, 2010 | 08:27 AM
no updates yet sorry. been very busy with other peoples cars lol.
got a set of headers to go on, but we are going to change to a more aggressive cam when we do the headers, along with a high volume oil pump and a nice double roller chain. should be late spring/early summer when we get this thing on the dyno....
Old Apr 6, 2013 | 06:16 AM
silverbulletls4's Avatar
Default going to be putting a ported ls2 intake with 90mm throttle body
What I am going to try is putting these RHS spacers between the intake and heads to try to see if i can get the bottom of the ls2 intake to fit over the vlom cover after I modify the opsu I've talked with racing head service they said it could work cause I still want to keep the DoD active because its still my everyday driver for now. I will keep you posted on how this works out cause these spacers are about 250.00 for a pair of them they are custom built for race engines.
Old Apr 6, 2013 | 06:20 AM
baltsk8er69's Avatar
With my intake swap I get the exact same mpg without dod as I did with. I just have it tuned out. I drive 95 miles round trip a day down i95.
Old Apr 6, 2013 | 01:09 PM
GXP25's Avatar
Those are indeed pricey for what we would actually need them for. In fact, that almost guarantees people would not have a problem modifying their replacement intake manifolds.
We need someone with a Chinese connection that can make these spacers for ~$40-$50 a pair. That way, hopefully, there would be no need to trim the DoD/AFM connector nor hesitate at the idea of removing the ribs from the bottom of the intake manifold.
And at what speed are you driving on I95 pray tell?
Old Apr 6, 2013 | 05:56 PM
  #32
I drive between 70-80. I should specify I get the same combined mileage. The point of posting my daily commute was to show I drive more highway than not.
Old Apr 6, 2013 | 08:07 PM
  #33
GXP25's Avatar
Unhappy
And that's exactly why I asked you about your speed. IIRC, DoD/AFM doesn't engage at those speeds/high RPM, etc. So it would make sense that you achieve similar fuel economy.
I drive down I95 weekly as well, albeit quite a distance away from you. DoD/AFM definitely does not engage.
There's a thread on one of those G8 forums where a guy tuned his GT to maximize the use of DoD/AFM: increasing the MPH limitation (85 MPH), RPMs, etc.
This is something I'd definitely like to investigate as I feel the stock tune is very restrictive with respect to DoD/AFM activation.
Old Apr 6, 2013 | 08:14 PM
  #34
I'm not trying to undermine your reasoning but I had my dod tune opened up. It does engage at higher speeds. I ran it for 4 weeks with 4 weeks without. I got 19.6 without dod 19.8 with. And the tighter cruising converter and overall feel is worth it to me. I'm not trying to sell tuning out dod I dont work for shell....ok I do but that's besides the point. Just my opinion.
  #35
Tuned by vince at trifecta fwiw.
Old Apr 6, 2013 | 08:16 PM
  #36
lVloses's Avatar
I believe 2k and under DoD is on, going 75 on a flat surface my DoD used to be engaged.
Old Apr 7, 2013 | 01:11 AM
  #37
91parkave's Avatar
Moderator
here u go
