HP Tuners LTFT
"Normally, use your Injector Flow Rate (IFR) Table to adjust Long Term Fuel Trims (LTFT's.) Adjust IFR values downward to decrease LTFT; this tells the computer the injector is smaller than what it now believes. Hence, more fuel is added, which compensates for what the computer believes is a lean condition based on O2 Sensor readings, and brings the LTFT adjustment more negative.
So, adjust IFR's upward to increase LTFT (opposite of what I said for adjusting downward).
Try to maintain about 18% Throttle Position Angle (% TPA) when tuning LTFT's.)
The intent of the IFR table is to introduce a constant that coincides with the injector size and the Fuel Pressure.
Theoretically, if you haven't changed the injector or changed your Fuel Pressure, you should not modify this table. If your LTFT's are out of whack, you should first look for vacuum leaks and other abnormal situations. However, mod'ing the car can alter the LTFT's, so you may be justified in changing them if there are no problems that would induce such a shift.
The logic behind zeroing or negating LTFT's is that when you go WOT, LTFT's will be zeroed, meaning no additional fuel is going to be dumped into the engine at WOT, and tuning will be easier. It has been argued that if you can obtain positive LTFT's of a consistent value, this is just as good, as the value is predictable, and thus tunable. That argument seems to have merit to me. But, it has been my experience that when I make LTFT's zero or slightly negative, my car REALLY wakes up at WOT. It even seems more responsive at part throttle. But that is MY experience."
Is this the way to go about it?
With that being said......on a stock car, your fuel LTFT's should be 0 or close to however, that is not always the case. I.E. my buddies 07 gxp was dead nuts 0 and so was my 00 corvette. However, my cousins 06 gxp was way off, like +10%.
One a stock car I like to adjust the MAF to compensate for inaccurate fueling. Like I said, everybody has their own method but I'm sure many good tuners will agree that the MAF is the best place to tune fuel trims on a stock vehicle. I also like to keep the stock shape of the curve, nice and smooth.
You might want to start reading old posts and tuning books. Google Greg Banish, his book is excellent and should answer all of your questions.
Thats good that you have a wideband hooked up. Are you going to post a copy of a scan or what?
Attached.
In fact, post your scan in the tuning section and/ or on the hptuners website, there will be others there that will help you as well.
BTW, what state are you in?
I just got done looking at your tune. I need more info. Why didn't you log MAP pressure? Does the commanded a/f ratio correlate to what you are getting on the wideband? If so that's pretty rich. Your long/ short term trims aren't working with the histogram and I'm too sleepy to figure out why.
How long has it been since you reset your fuel trims before this scan? Is doesn't look like they aren't "learned" yet. Make sure you drive around for a few days before taking the scan at face value.
IFR is dependent only on Fuel Pressure, injector size and manifold vacuum. The proper way to tune using LTFT's is to adjust the MAF curve and/or VE table by the LTFT number. There's some animated tutorials and tuning guides on the HPTuners forum that will explain things in more depth.
agreed, that pretty much backs up what I was saying. First lets start with a good scan. One, more time.....read Greg Banish's book haha
