(Experts only, ahem Mixerda) About to order cam and heads
Old 10-16-2009, 10:57 PM
neilownz's Avatar
Comp Cams part would be 850-16 and Lunati is 72332LUN. The comp ones are considerably cheaper. Comp also has a set that requires an adjustable valve train to set pre load or something 875-16.
Old 10-17-2009, 11:20 AM
Sittingmongoose's Avatar
The heads are patriot 2013 stage 2 heads. They need to have the exhaust ports matched to the headers because the ls4 exhaust ports are larger than the ls6 heads.
I ordered a conversion kit to go from the 1 bolt ls4 cam to the 3 bolt ls6 cam from lingenfelter, i had to call them because it isnt on thier site. It was 80$. They also had oem lifters so i got those and i dont know the part #.
The ls6 cam is the newer 04 and up cam with 0 miles. I got it from someone on this site.
The tuning and porting is going to be done by fasterproms when they come up to pa in early november.
Old 10-19-2009, 08:52 PM
i contacted fasterproms and decided to go with a stage 2 intake instead so that should help with the intake restrictions
Old 10-20-2009, 03:01 AM
StealthV8's Avatar
whats this stage 2 intake you speak of? just a level of porting or a new intake?
Old 10-20-2009, 09:40 AM
hahah its funny you say that, i think it is a more aggressive level of porting. Too what degree, i am not sure. But i guess i will find out. I am calling them today so i can ask.
Quick Reply: (Experts only, ahem Mixerda) About to order cam and heads
