Launching...
The one time i went to the track with my car i made 5 passes at Maryland International Raceway. I launched with out traction control for 4 passes, and couldnt get better than a 14.2. I launched with Traction control on and didnt do a burnout and i got 14.1.
Im new to drag racing. I did a newbie mistake. I was heating up the stockers. When you heat up those bridgestones, they get even slicker.
So, heres my advice, lower the front tire pressure about 5-7 pounds depending on the temperature outside. Then put another 5 or more in the rear tires. Also dont do a burn out. Let them spin a bit out side of the burnout box or as for no water, just to clean them off. Then give it a whirl with T/C on and OFF, just to see what turns out better for you. Oh and dont go to the track with a full tank of gas, thats just extra weight. I usually drive out there with a 1/4 tank left and it runs down with me driving there to less than that.
This is what if been reading up here an there. So the next time i go to MIR ill be doing that.
Good luck.
Greg
Did the OP ever run yet?
