Headers....but need 30 people.
Old Oct 23, 2009 | 09:42 PM
  #161
BuickRacer's Avatar
Guys,
I spoke with Nick T. (the R&D guy at Thorley Headers) today-- as it so happens, we both live just 10 minutes from each other on opposite ends of the same city. Due to our respective schedules, Nick and I have set up a time where I will drop off my vehicle at his home next Monday night 10/26 around 6PM-ish or so, then he will drive the car to their shop the following morning. I will then pick it up from him afterward, because...
...Nick & Co first need to look the vehicle over to see if what we're after is even possible. If it looks good, I will take the vehicle back to him AFTER the SEMA show which runs from November 1st through the 7th, as Nick and his crew are scheduled to be in Las Vegas for that. If the visual evaluation goes well, Nick anticipated about two weeks worth of work on the outside on my car. As an aside, in my correspondence with Nick he is very enthusiastic about the project; in fact, he sounded relieved when I called to tell him I could provide a "backup car" if he was still interested, and he very much was!
To answer a previous question, we have had no technical discussions whatsoever with regard to primary sizes or anything of that nature, nor would I anticipate that unless we have something viable in the works and they can pull it off.
'Till next time,
Morgan Hayden
Old Oct 24, 2009 | 02:45 PM
  #162
StealthV8's Avatar
sounds good, if this doesn't go through i may just cry
Old Oct 24, 2009 | 04:05 PM
  #163
DP 08 GXP's Avatar
^^^x2
Old Oct 24, 2009 | 04:25 PM
  #164
CenTexSS's Avatar
I'll just do the ported intake faster lol
Old Oct 26, 2009 | 10:18 PM
  #165
williamGT's Avatar
Guys, Nick from Dougs has BuickRacers car......hope for good news.
Old Oct 27, 2009 | 09:43 AM
  #166
05CherryGXP's Avatar
I'm in.
Old Oct 27, 2009 | 03:41 PM
  #167
williamGT's Avatar
Originally Posted by 05CherryGXP
I'm in.
Hey, if you don't mine to pm me your name address and phone number.
Nick from the shop needs it, for our 30 people list.
thanks
Old Oct 27, 2009 | 10:57 PM
  #168
BuickRacer's Avatar
Default Update Report #1
I just retrieved my car from Nick at Thorley and wanted to provide a preliminary report:
Nick drove the car today to their shop...from what he tells me, the general reaction from "the crew" was along the lines of, "Umm...what's so special about this car?" Then he pulled the hood release. "OOOOhhhhh...."
The car spent the day with the hood open. The initial evaluation is that the project is not impossible, but it will require quite a bit of work due to the lack of room. Ideally the goal is to run two downpipes into a single merged collector underneath, with the front following a similar path the OEM crossover has now. I will be returning the car to Nick the Monday following the SEMA show.
Until next time,
Morgan
Old Oct 27, 2009 | 11:05 PM
  #169
neilownz's Avatar
Coolio. Time to wait for a couple/three weeks.
Old Oct 27, 2009 | 11:14 PM
  #170
TheMonteMan's Avatar
sweet
Old Oct 27, 2009 | 11:23 PM
  #171
williamGT's Avatar
sweet, so my hogan DP is going to be useless? But I hope it will happened....header
Old Oct 28, 2009 | 01:09 AM
  #172
neilownz's Avatar
I'm sure someone might be interested in buying it. Damn you could go with like a 2x3 to 4 inch exhaust collector or true 2.5-3 duals... should be plenty for just a 5.3L.
Old Oct 28, 2009 | 02:32 AM
  #173
StealthV8's Avatar
if they are going to run two downpipes i will happily get rid of my w-bodystore downpipe.
Old Oct 28, 2009 | 03:38 AM
  #174
williamGT's Avatar
but it should bolt on stock and magnaflow catback?
Old Oct 28, 2009 | 07:44 AM
  #175
Corny40's Avatar
Is the "quite a bit of work" going to add to the projected cost?
Old Oct 28, 2009 | 09:35 AM
  #176
neilownz's Avatar
Doubt it. Just might need a second flex joint and a little more pipe, but shouldn't be any real complex bends. I would guess a slip joint before the cat would be easiest since the some people might want to pass inspections. Wouldn't kill me if it bolted to the cat back though. They will need to put some sort of connection in there to install it. Maybe a ball and socket in between the front+crossover and the rear+downpipe...
Old Oct 28, 2009 | 11:27 AM
  #177
This might be beyond Nick's ability to predict, but is his work going to have noticable impact on emissions when the headers and exhaust are rigged up? ******* states with yearly emissions inspections!
Old Oct 28, 2009 | 12:17 PM
  #178
neilownz's Avatar
You'll become a pro at removing/installing the stock ones. I'll take an offroad version that bolts to the cat back k thx.
Old Oct 28, 2009 | 01:48 PM
  #179
Vectus's Avatar
I just go to a different part of town, and they dont give a damn. lol
Old Oct 28, 2009 | 04:28 PM
  #180
GXPRIX27's Avatar
if they do the downpipe setup ill take the offroad version also, cats are gay i like my catless hogan
