For those who think our intake is restricted
Old 10-20-2009, 09:55 AM
Sittingmongoose's Avatar
Default For those who think our intake is restricted
https://ls1tech.com/forums/generatio...e-porting.html
Check that out. Fasterproms is now offering stage 2 porting. I am getting this done to mine. Should help to lessen the horrible intake we have. We are getting closer to having a modifiable car.
o and i already talked to Jeremy, he can do this for our intakes as well.
Old 10-20-2009, 10:13 PM
JDMC5's Avatar
the LS4 intake is stupid restrictive.....so is the cam and so is the exhaust.
Old 10-21-2009, 01:15 PM
well thats why this stage 2 intake would be great, that way people can get the benifit of having a new intake without having to retrofit a ls6 intake to fit
Old 10-21-2009, 06:20 PM
TheMonteMan's Avatar
post pics when you get yours done.
Old 10-21-2009, 07:08 PM
CenTexSS's Avatar
That looks great. I might be doing this soon.
Old 10-21-2009, 08:46 PM
o i will, i have an appt for the 13th to get it done. expect my post that night o and thats going to include a before and after dyno too
Old 10-21-2009, 09:25 PM
CenTexSS's Avatar
Will you be getting the heads/cam done at the same time?
Old 10-21-2009, 11:47 PM
JDMC5's Avatar
Oh I agree, it should help. I think the area behind the TB is the big restriction though. One person had good success fitting an LS2 intake on his LS4. Never got any hard numbers but IIRC he said the SOTP improvement was big.
That intake is so restrictive I wouldn't be surprised it hear 20hp improvement just by switching to a stock LS6/LS2 intake.
Old 10-22-2009, 06:37 PM
I will be doing the heads and cam next week than a tune and the intake on the 13th.
He did have good sucess but it required a lot of money and modding. Also if you do the stock intake you cna keep the DOD
Old 10-22-2009, 09:47 PM
JDMC5's Avatar
DOD = GARBAGE. I still don't get how my vette could get 30mpg on the freeway but a smaller engine with DOD can't.
Old 10-22-2009, 10:27 PM
CenTexSS's Avatar
We can get 30mpg highway.........
Old 10-22-2009, 10:56 PM
neilownz's Avatar
If we had more than 4 gears it might be even better.
Old 10-23-2009, 02:04 AM
i get well over 30, and neilz you had put different heads on right?
Old 10-23-2009, 02:30 AM
neilownz's Avatar
Yeppers.
Old 10-23-2009, 09:47 PM
Compg's Avatar
It's about 1000lbs lighter.
Old 10-23-2009, 10:47 PM
mike690003's Avatar
And the low drag coefficient helps too....
Old 10-24-2009, 12:29 AM
JDMC5's Avatar
so you're saying the grand prix weights 4200 lbs? hardly, try 400. Shouldn't make that big a difference.
Old 10-24-2009, 01:14 AM
JP_GXP's Avatar
Mine has gotten 30 mpg, with DoD tuned out.
I'm sure weight to power ratio and more gears helps a little too.
Old 10-24-2009, 10:08 AM
Striker's Avatar
So you guys can't swap over to an LS6 intake, or any other intake for that matter?
Also is the exhaust that restrictive??
Old 10-24-2009, 01:31 PM
neilownz's Avatar
LS4 powered cars are the stepchild of GM. Either the oil pressure sender or the power steering stuff is in the way. The rear manifold is terrible.
