Upgraded fuel pump?
http://www.cottonsperformance.com/products.asp?cat=60
...and scroll down about 2/3 of the way down the page. You'll note that is says, "Hot wire kit recommended". If you need help on how to make your own hot wire kit, PM me.
When I raced my '99 supercharged Regal, I hotwired the stock fuel pump and bypassed the silly fuel pump ballast resistor circuitry; the idea of the resistor was to slow the pump down to reduce noise at cruising speed. I did away with all that and used the factory fuel pump wiring to trigger a relay which fed +12V via a 10AWG feed I ran to the back of the car through the passenger compartment, and into the trunk where the fuel pump access was located. Typically the gray wire in the fuel pump harness is your feed; black is ground, and purple is the fuel sender.
https://ls1tech.com/forums/fueling-i...ick-cheap.html
I’m thinking I could use the stock pump and add a Walbro 255 on a boost referenced switch. However we have a return less fuel system and I don’t know if we have room in the tank for two pumps. Any body had their pump out or know if this will work?
The pictures in the link you posted is very much what my setup looked like with the same pumps. The only change I would make in the F-body thread is that he is using the small gauge factory wiring to run one pump and too small a gauge +12V feed wire on the second. These pumps take a lot of juice and the larger the gauge wire you use, the more voltage that gets to the back. You need both pressure and volume, particularly on a forced-induction application such as the OP's. I used two 20A fused feeds off the back of the alternator (one for each pump) to two relays (labeled "primary" and "secondary"), then from there two 10 AWG feeds ran to the back of the car; the only wire I used in the factory harness was for the fuel sender. I then located the +12V for the factory fuel pump in the engine compartment and used that to trigger the "primary" relay; doing so retains the 2-second fuel pump prime feature when you first turn the ignition key.
http://www.mphparts.com/prod/107-2350.html
On my buick I also have a double pumper system. They work great.
Thank you,
Barry
