cam question, how big is too big.....
Old Nov 15, 2009 | 10:52 AM
crazyjoe's Avatar
Default cam question, how big is too big.....
So, how big is too big on a stock stalled LS4? The factory converter seems extremely loose making me "think" that you could run a fairly big cam pretty easily.
The reason I ask is because my brother is pondering selling his '00 WS6 with an MTI X1 cam, 230/227 .591/.571 lsa 112, with comp 918 springs and hardened pushrods, so I was gonna take that cam package from him before he sold it. Would those specs be overkill in an LS4? I ran a 224/224 cam in my '02 WS6 on the stock stall for a while and it was fine, but I realize this is a different scenario. Any thoughts?
Joe.
Old Nov 16, 2009 | 12:06 PM
Sittingmongoose's Avatar
WEll i can tell you that the 04 and up ls6 cam is no where near enough lift to see a difference
LS6 CAM - 204/219 .551/.548 117.5
If you do a cam in our car, it better be WAY more aggresive than the ls6 because the ls6 yielded no gains on my car.
Old Nov 16, 2009 | 01:52 PM
neilownz's Avatar
Didn't I comment on this already? Ghost posts. Anyways I said you will need new lifters, ls2 lifter retainers, new head gaskets and bolts, and you have to ditch dod with that much lift. Dual springs would be a better choice than the 918s.
Old Nov 16, 2009 | 03:53 PM
crazyjoe's Avatar
The DOD will definitely be ditched, and i will invest in the proper lifters and such, but my main concern would be the driveability on the stock converter.....think it will create any problems? Will it feel like an absolute turd out of the hole?
Old Nov 16, 2009 | 04:52 PM
someday's Avatar
remember that ur also dealing with a smaller engine, 5.3 vs 5.7... that X1 was pretty big in a 5.7, so it will be very soft on the low end, and make power past 6000, where u hardly drive, and it will not make the trans very happy having to spin that high...
Old Nov 16, 2009 | 05:24 PM
I am not sure as i did the highest lift cam i have seenyet on the car, try it and see what happens
Old Nov 16, 2009 | 06:03 PM
crazyjoe's Avatar
If I can get it for free I might try it just for fun, otherwise I might try a something along the lines of a 224 cam. Not that any of this is happening any time soon, but I still wanted to hear some thoughts.
Sittingmongoose, I cant believe you didnt see any gains with the LS6 cam, that sucks man. What is your car trapping in the 1/8, 1/4?
Thanks for the input fellas.
Joe.
Old Nov 16, 2009 | 07:19 PM
I am prolly like 13.1 I got owned by a regel that runs 12.9
Old Nov 16, 2009 | 08:39 PM
JDMC5's Avatar
the LS6 cam is FINE for this car, but don't waste your time on ANY cam without swapping that intake and getting some headers.
As soon as that cam starts to make power, the stocking manifolds stop making power, negating any gains from the cam.
Old Nov 17, 2009 | 02:59 AM
blakss's Avatar
Talking
what do you guys think about the New wra performance low lift and high lift DOD cams? iv been researching them as im considering their cams as i would like to keep the DOD at least for now..as i just want to upgrade the powerbands a bit..not looking for a race car feel as this is my daily driver but do like to have fun with it.
Old Nov 17, 2009 | 11:17 AM
i blew my dod lifters so i am nervous about putting power down and keeping dod
Old Nov 17, 2009 | 04:10 PM
blakss's Avatar
they cant handle alot of power or something?
Old Nov 17, 2009 | 04:49 PM
JDMC5's Avatar
It's not an issue of power its valve lift, ramp acceleration and valve spring pressure that put the most stress on the lifters.
Old Nov 17, 2009 | 07:51 PM
Mgpeagle's Avatar
After all the cam swaps I have read about I am opting just to keep the LS4 cam. I do however run 1.85 rockers though. It's a great combo for low, mid, and upper gains. I bet headers on this combo would be even better.
-Mike
Old Nov 18, 2009 | 04:54 PM
you its funny you say that, i had put old harland sharp rockers on them that were 1.85, when i sent them back to harland sharp they said they were 1.85 and than they sent me 1.8
Old Nov 19, 2009 | 01:24 AM
blakss's Avatar
i know we're talkin about cams and rockers here, but do you guys think some LS6 springs with 1.85 RR's would be a good combo..? dont really understand the lift and spring differance. i believe the LS6 springs are a .550 lift compared to the rest with a .650 lift and springs.. just lose me .. lol beehive,duals..i dont get it so seeing as you guys are Pros.. lol what would you guys recommend?thanks in advanced.
Old Nov 19, 2009 | 01:54 AM
JDMC5's Avatar
yes, LS6 springs should work just fine.
Old Nov 20, 2009 | 02:44 AM
blakss's Avatar
ok cool thanks jdmc5
and can someone help me out in understanding how much of a diffrence there is in between .550 and .650 can you really tell the diffrence with higher ratio roller rockers and ls6 springs ?and how would you know when you need to upgrade.right now i got smaller upgrades but looking to start with the internal work.. aside from headers and intake ..
Old Nov 20, 2009 | 08:51 AM
Mgpeagle's Avatar
I ran the stock valve springs but used oil restricted pushrods. I got a deal for SLP rockers for 200.00. They usually go for 500.00 or more. I have had them on the car for about 5k miles with no problems. I also have the DOD shut off.
-Mike
Old Nov 20, 2009 | 10:20 AM
SidewaysV8's Avatar
-Mike
Mike,
You still have the stock lifters in though don't you? Or did you get rid of them when you changed pushrods?
Craig
