Looking for transmission build info
Old Dec 9, 2009 | 08:38 AM
Tempest790's Avatar
Yeah, but the 1" chain isn't available from ZZP anymore. They're out. They sold the last ones at $1200 each. I wish someone in the aftermarket would begin producing them.
Old Dec 9, 2009 | 09:15 AM
nmp0098's Avatar
Originally Posted by GXPJAY
And there is no way the stock chain will do mid 12's on slicks..lol NO way
It came out wrong, but that's what I meant. Dave said the stock chain is good until you start running mid 12s on slicks, and then it will break after a few passes. He said high 12s are fine, which is my target. He also said that if you can hit mid 12s on slicks, but keep your street tires on and run high 12s, you are still good. I got the impression, and it makes sense, that 1st gear + a hard launch is what snaps the chain, not the amount of power you run through the trans.
Old Dec 9, 2009 | 09:42 AM
GXPJAY's Avatar
1-2 shift at WOT is what will snap the chain, street tires or slicks it will snap.
Old Dec 11, 2009 | 04:42 PM
Tempest790's Avatar
I have a question. Now that the 1" chain is moot, I wonder about the 7/8" vs. the 15/16" chains. Intense seems to prefer the 15/16" while TEP uses the 7/8" (which is what I went with). I poked around some websites and forums and the consensus is that neither is stronger than the other but the 15/16" will snap while the 7/8" will stretch (both bad in their own way).
TEP said the 7/8" is good for about 400-450 whp. Anyone know if that's true for the 15/16"? I'm just curious since others will be getting their transmission rebuilt I think it might be good to see if anyone has first hand experience.
Old Dec 12, 2009 | 11:54 AM
nmp0098's Avatar
That makes sense... I already chirp the tires during a WOT 1-2 shift. I wonder how the chain would hold up to an all-motor 1-2 shift and a 2-3 shift near the end of a 100HP wet shot. Less of an RPM change, but more torque on the chain.
According to Intense's website, they mount the 15/16" chain on the same 3/4" sprocket that they use with the 7/8" chain, and they claim that the shock load resistance is the same for both chains. They also claim that the 15/16" doesn't stretch as easily (fatigue is the word they used). Without knowing, I'd guess that power capacity is therefore similar. I'd also guess that the reason you heard of the 15/16" chain snapping is that you don't get the early warning of a stretched 7/8" chain slopping around and making noise for a while before it snaps.
Old Dec 12, 2009 | 01:54 PM
1Fast7's Avatar
I'd say run two chains and call it a day. It is kinda of discouraging the motor has so much potential but we are limited with the trans. I hope that with the prices of the cars falling and them getting into the hands of those of use that want a little more out of them the market will start to cater to us. The big problem though is price. Being the first usually hits the pockets bad.
Old Dec 29, 2009 | 09:49 AM
Tempest790's Avatar
Originally Posted by nmp0098
This car has a small TCM because the LS4 requires a dedicated ECM. Anybody with HP Tuners can change the tune, it will just take 2 credits. If you know someone who has HP Tuners in your area, you should be able to pay them for the credits you burn. I can send you my base calibration and the one that worked with the gear change when the time comes if you PM me. I hadn't done any other tuning at that point.
PM sent.
Old Feb 24, 2010 | 07:11 PM
Tempest790's Avatar
Oh yeah! I am one happy customer!
Dave at TEP got the PCM/TCM re-programmed. I guess I'm the first 08 to have this done, because there were a lot of differences in the PCM compared to the 07 and earlier models. Took awhile, but it was worth it.
The gear ration change is definitely worth it! Much harder launches. In fact, my poor RS-A's can't even keep any traction from a WOT launch at 2500+ RPM. Those tires are pathetic. Some tire upgrades may be in order this summer.
The shifts are so fast and crisp, I was very impressed. This is my first performance transmission, by the way. I can't sing the praises of TEP enough. He really went above and beyond to get me up and running.
Talk about making this car even better. I know I still get bashed on for FWD, but I just showed my friend what this baby can do. Ha ha!
Old Aug 7, 2010 | 05:46 PM
hurley08gxp's Avatar
hjgfgj
Old Aug 7, 2010 | 06:17 PM
AlabamaGuy's Avatar
Originally Posted by hurley08gxp
hjgfgj
Thank you for that useful post.
Old Sep 9, 2010 | 02:21 PM
hiiiii
Old Sep 9, 2010 | 03:26 PM
  #32
Bryan921SS's Avatar
Is someone trying to boost their post count??
Anyone ever see the 1" Chains for sale anywhere??
How do the 7/8" Chains hold up?
Old Sep 9, 2010 | 03:29 PM
  #33
Vectus's Avatar
im at about 16K 8 months and mines doing just fine.
Old Sep 9, 2010 | 03:47 PM
  #34
Hawkins04's Avatar
i have not seen the 1'' chains anywhere I would like to get one
Old Sep 9, 2010 | 04:25 PM
  #35
Nacho SS's Avatar
They don't make them anymore. I've seen used ones being sold for over 1k.
Unreal.
Old Sep 9, 2010 | 04:40 PM
  #36
Hawkins04's Avatar
yea I know they dont make them anymore i meant i havent seen any used ones in awhile. I have seen a few go over the 1k mark and that is crazy
Old Sep 9, 2010 | 05:05 PM
  #37
LS4_DeltaV's Avatar
We have a car running 630 WHP and a 15/16th chain. Hasnt broken yet. However its been reccommended to change it every 25-30,000 km.
Cheers
Old Sep 11, 2010 | 08:48 AM
  #38
1BAD06MCSS's Avatar
Does anyone know that when you change your ratio, you have to get a tune to make it run right?
Old Sep 11, 2010 | 08:49 AM
  #39
1BAD06MCSS's Avatar
I am thinking of doing this mod and just would like to get everything in order so I can get it done correctly.
Old Sep 11, 2010 | 03:24 PM
  #40
RA4926's Avatar
Side note: How much power is the 4t65 rated for?
