winter MPG
Old Jan 12, 2010 | 01:43 PM
baalic's Avatar
Originally Posted by nmp0098
But, with higher octane and lower density fuel you have less energy per gallon and so you get worse mileage.
I thought that gasoline was more dense in the winter ((cold weather)).....unless your saying they make a less dense gasoline for the winter.....
Old Jan 12, 2010 | 01:58 PM
MidLifeCrisis's Avatar
Originally Posted by 94ss06gxp
there is a sunoco about 15 miles from my town tho, would it be worth it to go there?
Yes. I would stay away from shell, citgo and definitely meijer gas. Not sure about marathon...
Old Jan 12, 2010 | 02:48 PM
Bryan921SS's Avatar
I thought shell gas was some of the best...why does it cause more kr??
Old Jan 12, 2010 | 10:24 PM
nmp0098's Avatar
Exactly. Because fluids are more dense and less volatile in the winter, they reformulate the fuel with additives. Most Northern states mandate it. It helps cold starts.
Old Jan 13, 2010 | 02:49 AM
02ws602wrx's Avatar
Didn't know that about the fuels. Hope that the gas mileage isn't that bad looking into the Impala SS. Need DOD do alot of hwy drivin
Old Jan 13, 2010 | 12:59 PM
94ss06gxp's Avatar
i dont even think there is any of those in my town, mostly shell, citgo, speedway, meijer , and marathon. those are all of the gas stations in my town, i google mapped it and thought about it, there is a sunoco about 15 miles from my town tho, would it be worth it to go there?
so anybody know what gas station i should gas up at??
Old Jan 13, 2010 | 03:42 PM
baalic's Avatar
Ahhh does this hold true for states like Texas??
Old Jan 13, 2010 | 10:33 PM
nmp0098's Avatar
Sorry, the only states I can say for sure uses winter gas are MI and OH, and that's cause I've lived there. I got curious myself, and apparently there's an emissions component to all of this too. Seems like some major urban areas are mandated to use reformulated gas in the winter. I don't know how up to date or thorough this is, but:
http://www.eia.doe.gov/emeu/steo/pub/special/rfg2.html
http://www.eia.doe.gov/emeu/steo/pub/special/oxy2.html
Old Jan 14, 2010 | 01:06 AM
justin455's Avatar
Douchebag On The Tree
Also they add anti-gelling agents to the gasoline for when it just gets that f*in cold. So your 1 gallon of gas isn't technically as much of a gallon anymore.
Old Jan 14, 2010 | 01:27 AM
JP_GXP's Avatar
Running pig rich, no cat/rear O2... managed 26 mpg from Ruston to Little Rock and back, playing a little both ways. All 8 cylinders, DoD disappeared a long time ago. Never got over 30*, started the trip at 24*.
I used to use Shell, but swapped to Chevron a few months ago, probably not any better. Our only BP closed and is now a Texaco (which I thought was bought as by Valero but apparently not).
Old Jan 21, 2010 | 12:28 PM
shady milkman's Avatar
Originally Posted by Sittingmongoose
using shell gas might be part of the problem. Shell will produce more knock than other providers.
Originally Posted by MidLifeCrisis
Mobil, BP and Sunoco are good gas stations. I'd recommend either of these...
the top tier gas stations are as follows
QuikTrip
Chevron
Texaco
MFA Oil Co.
Conoco
Phillips 66
76
Entec Stations
Shell
The Somerset Refinery, Inc.
Kwik Trip / Kwik Star
Aloha Petroleum
Tri-Par Oil Co.
Turkey Hill Minit Markets
Mileage Stations
Road Ranger
CountryMark
Chevron Canada
Shell Canada
Petro-Canada
Sunoco Canada
notice sunoco for north america is absent. Sunoco goes for the cheapest gas and then adds their detergents..that is a known fact. ask any riggers who transport gas.
shell is filtered 7 times compared to the average 2-3 times. on top of that i dont know where you get shell causes more knock..as they have a good amount of heavy alkanes .. obvious depending on your area, your tune, and the amount of ethanol in the mix will determine the likely hood of getting knock.
by the way..BP is aweful gas as of the past few years. id stick to shell, chevron, and if needed..a marathon. but stay away from sunoco and bp for sure
Old Jan 21, 2010 | 12:38 PM
  #32
94ss06gxp's Avatar
i run 87 octane from Meijers gas station and i can feel the power
Old Jan 21, 2010 | 09:15 PM
  #33
Count of Monte Carlo's Avatar
I average 19-20 mixed, depending on who is driving bad that week. In the summer I get 22 mixed. And if I am really good I can squeeze out a 23.
