rpm drop in 2nd gear
Old Jan 22, 2010 | 03:22 PM
94ss06gxp's Avatar
Default rpm drop in 2nd gear
ok so if i put my gxp in tap shift and in second gear give it half to 3/4 throttle at about 3700rpm it wil drop back to 3500rpm with steady throttle but it doesnt do it at WOT. doesnt effect drivability or anything just seein if its normal?
Old Jan 22, 2010 | 06:53 PM
TiredGXP's Avatar
It's probably just the torque coverter "flashing" at the lower throttle setting.
Can't be the TCC, since it doesn't engage in second gear unless you are in "hot" mode.
Old Jan 25, 2010 | 07:57 AM
07SSport's Avatar
Im seeing the same thing happening. My RPM's will drop with steady throttle in 2nd gear, anywhere between 2000 and 3700 RPM's. Noticed that this started after the car shut itself off one day on the highway. I cant tell if its normal or if my Throttle Position Sensor is tweaked.
Old Jan 25, 2010 | 02:52 PM
94ss06gxp's Avatar
i see mine everytime im half throttle at 3700, but normal driving conditions i shift at like 3000 or so, so i only see it when im accelerating kindsa fast, im guessing its normal cuz it happens everytime at the same rpm.?
Old Jan 26, 2010 | 11:45 AM
07SSport's Avatar
Well I guess we will find out in the long run... I dont think that just because it happens everytime at the same RPM means its normal, but it definitley makes it easier to keep an eye on.
Like I said... I never noticed it happening prior to my car just shutting itself off, so I dont know if its a sensor issue? TPS, MAF or even some ECM or BCM related issue. I scanned for codes and nothing popped up though, so who knows.
Old Jan 26, 2010 | 12:58 PM
94ss06gxp's Avatar
yeah for sure keep an eye on it. i will get a video of it soon and post it up.
Old Jan 27, 2010 | 07:32 AM
07SSport's Avatar
Thatd be great... I can never tell if Im being paranoid with this crap or if its really an issue.
BTW... Which car do you have more fun driving the 94 SS or the GXP?
Old Jan 27, 2010 | 10:08 AM
94ss06gxp's Avatar
id have to say the impala, cuz its rwd and its way louder, not faster tho. but for 5000+lbs it can sure smoke the tires
Old Jan 27, 2010 | 01:38 PM
94ss06gxp's Avatar
tryin to upload the videos but they are winzip files and way over the limit, i can email them to you 07SSport if you give me your email.
