Spintech Cat Back Installed -Video-
Old Jan 26, 2010 | 09:25 PM
AlabamaGuy's Avatar
Default Spintech Cat Back Installed -Video-
Alright guys, finally got all of my pieces together to build a full 3" mandrel system to replace my pieced together shambled mess of an exhaust. My current setup is a 3" catless DP into a stock cat back with no resonator, a cutout by the rear control arms, and 2 Flowtech Afterburner mufflers run through stock tips. I don't want to give away the ghost before I get the new muffler on but I'm hoping to kill some of the ungodly rasp my motor makes when I'm running through the mufflers. My main reason for making this, however is to have a much better flowing exhaust to back up the new headers. The added plus will hopefully be a little bit of originality. I know this thread is useless until tomorrow, but can anyone guess what setup I'm going to use?
EDIT:
Put the exhaust on today, finally! Well, it's mostly on. I still have to run it another foot or so with a tip to get it out from under the car. It got dark on me installing it so before/after videos and pictures will come a little later. Right now it's still dumped under the car and doesn't have any isolators on it so the vibration inside is pretty bad. However, this muffler really helps it not to sound so much like a farm truck.
I put a flange on 3" exhaust from the Hogan DP into a 4x6x12" Spintech Pro Street muffler. Then I did around a 75* bend toward the passenger side with another foot or so of pipe going in the general direction of the back tire. In the next few days I'll be installing real hangers with isolators and running the exhaust on out the side of the car. If anything, I saved a good 40# by dumping the extra muffler and all that piping, but I'm SURE the 3" mandrel will flow a whole lot better than the stock piping. Well guys, sorry I don't have pics or vids yet but I promise they are coming.
Old Jan 27, 2010 | 05:48 PM
AlabamaGuy's Avatar
Bump for the update
Old Jan 27, 2010 | 05:52 PM
94ss06gxp's Avatar
sounds like a good little system to me, good job!!
Old Jan 27, 2010 | 06:40 PM
Nacho SS's Avatar
So basically you just cut and dumped it with a relocated muffler? How are cops on noise pollution in your area?
Old Jan 27, 2010 | 06:47 PM
AlabamaGuy's Avatar
I had a turndown on it and it was too loud so I ran it out to the wheel.
Well cops here don't exactly care about anything.
Old Jan 27, 2010 | 07:15 PM
AlabamaGuy's Avatar
I may end up adding a bullet muffler close to the outlet. It's very loud. It's pretty close decibel wise with the open cutout just doesn't have the rasp.
Old Jan 28, 2010 | 01:34 PM
Sittingmongoose's Avatar
video or sound clip?
Old Jan 28, 2010 | 02:03 PM
AlabamaGuy's Avatar
Hopefully tonight, if not...tomorrow.
Old Jan 28, 2010 | 08:32 PM
AlabamaGuy's Avatar
As promised, it's not a great video but you can hear it in normal driving. I'll get a better one tomorrow:
http://www.youtube.com/watch?v=mF4McXl4CKU
Old Jan 28, 2010 | 09:10 PM
1CL3ANSUP3RSPORT's Avatar
Sounds mean,I like
Pics of the set up???
Old Jan 28, 2010 | 09:13 PM
AlabamaGuy's Avatar
Originally Posted by 1CL3ANSUP3RSPORT
Sounds mean,I like
It got dark on me tonight, if the weather holds out I'll grab a few with better videos tomorrow.
Old Jan 29, 2010 | 01:39 PM
TheMonteMan's Avatar
sounds real good. need some outside and full throttle vids though.
Old Jan 29, 2010 | 10:14 PM
DP 08 GXP's Avatar
X2 but it does sound good so far
Old Feb 1, 2010 | 01:11 PM
AlabamaGuy's Avatar
http://www.youtube.com/watch?v=TVdnLFtswoQ
Old Feb 1, 2010 | 04:19 PM
Nacho SS's Avatar
Not bad, it sounds a bit too blownout/low pitched for me. But you're going for overall performance so it works perfectly. It may get really annoying like that, just my opinion.
Old Feb 1, 2010 | 04:24 PM
AlabamaGuy's Avatar
That's the 3" piping. I'm trying to eliminate any bottlenecks before the headers go on, and I believe they are going to help with sounds tremendously. I have a theory as to why our cars sound the way they do. I believe the way the manifolds are designed, the pulses are upset by all the air from the front entering the flow of the back manifold. I have a feeling that's why it doesn't sound like an LS motor, the 4-7 swap can't be heard like it can in other LS engines therefore: we sound more like a Gen 1 or 2 engine.
Old Feb 1, 2010 | 10:41 PM
DavidGXP's Avatar
I love it, check out my Spintech's.(Not to jack your tread or anything.)
Hear's the details. https://ls1tech.com/forums/ls4-front...ng-custom.html
Old Feb 1, 2010 | 10:50 PM
DavidGXP's Avatar
Sorry for the doubles... wow!
And listen to that lazy stock shift!!
Old Feb 2, 2010 | 01:21 PM
RickAKATed10's Avatar
I think it sounds really nice. I'm sure you've posted this some where before, but do you have DOD/AFM turned off? Also were your videos taken with the windows up or down?
Old Feb 2, 2010 | 01:33 PM
BlueBird346's Avatar
Sounds good Travis. Im ready to hear it with the headers.
