LS1 intake here I come!!!!!
Old Apr 1, 2010 | 06:57 AM
Tappeter's Avatar
Credit neilownz for the following...
http://chevythunder.com/drive_by_wire.htm
As you can see it's probably also possible to use the 1998-2005 corvette ones with the two wiring connectors. Both of those tbs will bolt up to the ls6 manifold.
The truck one is the newer design and would be the best option other than making an adapter plate for the manifold.
One of these.
http://www.bmotorsports.com/shop/pro...oducts_id/1084
One of these. The 03-06 Truck Throttle Body Pigtail.
http://www.eficonnection.com/eficonn...omponents.aspx
Eight each of these.
http://www.bmotorsports.com/shop/pro...roducts_id/559
http://www.bmotorsports.com/shop/pro...roducts_id/628
If you wanted to keep it stockish.
Old Apr 1, 2010 | 06:59 AM
Tappeter's Avatar
The connector is the same, but the wires are different. I have it somewhere if this helps.
8 pin LS4
A TP Sensor 1 Signal
B 5 Volt Reference
C Common Ground
D TP Sensor 2 Signal
E TAC Motor Control - 1
F TAC Motor Control - 2
G 5 Volt Reference
H Common Ground
8 pin truck
A TAC Motor Control - 1
B Common Ground
C TAC Motor Control - 2
D Common Ground
E 5 Volt Reference
F TP Sensor 2 Signal
G TP Sensor 1 Signal
H 5 Volt Reference
credit neilownz for this
Old Apr 1, 2010 | 08:38 AM
neilownz's Avatar
There are two versions of the 8pin truck tb. A 4 bolt and a 3 bolt. They might use the same motors though. The new one is in like 06+ tbss, silverados, sierras, etc.
Old Apr 1, 2010 | 11:00 PM
DavidGXP's Avatar
Originally Posted by JDMC5
I'd be willing to bet a large sum of money against this one.
It has been stated by GM engineers and many magazine articles and other techs that the LS6 intake is about 10hp stronger then the LS1 intake above 4500rpm.
http://www.tpis.com/pages/2_17_06
Built LS6 with cam and headers with tuning
http://www.cartechbooks.com/vstore/s...=3048&CATID=21
Another cammed LS6 with headers.
On a smaller engine with a smaller cam and less gear I would opt for the LS1 intake and if I had a built motor I'd just spend the extra money on a FAST manifold.
I'm all for the LS6 intake, but I don't think one should "have" to have it over the LS1 intake unless they were both the same price. Withe our stock cam, small cubed motor it will be fine and make plenty of power. 60.00 for about 20hp at the wheels is a great deal! Plus, I wouldn't feel bad cuting it up.
Tappeter's Avatar
I have a 3 bolt truck TB bought on ebay, it has the same 8 pin connector as the LS4 and bolts right to LS6 manifold. I just made an adapter cable thanks to neilownz info. The TB and manifold neck mating surface is not completely round as in the LS4, but the standard odd shape with extra open area on top right. I am guessing this was designed this way to dampen intake air sounds/noise. I used this extra area as a place to tap for vacuum fittings for pvc and brake booster. See the photos in above post
Old Apr 2, 2010 | 12:29 PM
Haulin_Ls4_GxP's Avatar
Once again I will try and make myself clear for those of you that CAN'T F$%^IN READ. I didn’t want to go with the LS6 didn't want to spend the extra money on it not to mention the fact I was going to be cutting it. So please stop telling me to go with the damn LS6 manifold! Am I being a dick head yes I am, but I am sick of people that can’t see that I did this to gain a bit of power for a little money. Thanks Tappeter, DavidGXP and neilownz for the help!
Old Apr 2, 2010 | 01:35 PM
One of these.
None on the links work hmmm...
Old Apr 2, 2010 | 03:17 PM
DavidGXP's Avatar
This is what I used
http://www.bmotorsports.com/shop/contact_us.php
CONN-85616 x1 Map extension harness
CONN-56555 x8 Seals
CONN-100148 x1 Connector to stock LS4 pigtail
CONN-56460 x8 Pins
03-06 pigtail adapter x1 (site does not list part number just a buy it now icon)
Old Apr 2, 2010 | 04:29 PM
JDMC5's Avatar
relax dude, nobody is telling you what to do were just making sure you are well informed before you go........"wish I had installed an LS6", but whatever.
@DavidGXP, yes the LS6 is "rated" at +10hp over a stock ls1 but people commonly see +15 at the wheels over the ls1. Don't forget GM was a little over conservative with their power ratings a few years ago.
Old Apr 2, 2010 | 08:27 PM
DavidGXP's Avatar
Not bagging on the LS6 intake in no way shape or form. I know it's better and if I had an engine that already had one on it, then I would never ever consider down grading to a LS1. Now, in the LS1's defense, the Z06 had upgraded heads, pistons (more Cr), maf sensor worth 2-3hp and camshaft. GM said that the new manifold was 10 hp stronger. Now, the ZO6 was made to rev a little higher so a new intake was a must.
The 01-02 F bodys got the LS6 intake and the LQ4 camshaft with less lift then the previous F cars. Also, GM removed the EGR and added better flowing exhaust manifolds All of this added 5hp total. Swapping the LS6 intake onto a 98-00 LS1 is a popular trend cause its a direct swap and they have the better cam, but... why not go F.A.S.T intake? Cost!
The writing is on the walls with the article's I posted above. I truly do not believe the LS6 intake on our motors, is worth the price for just a few ponies upstairs. Cost!
Once we start swapping cams and raising compression I would be more inclined to defend the LS6 intake.
Seriously, read those articles and look at the graphs. Then, stop and think about the cams there using, and the LONG TUBE HEADERS, electric water pumps, tb's and expert tuners. Then stop and think how much power that would be at the wheels.
Old Apr 2, 2010 | 09:58 PM
And as I said in my 2nd post in the thread after you told me the ls6 was better which I knew already. I said thanks for the input and then explained why I went with the ls1. Thats why I got pissed about the whole thing. but again thanks for the input!
Originally Posted by DavidGXP
This is what I used
CONN-56555 x8 Seals
CONN-56460 x8 Pins
Thanks for all your help David I just ordered everything I needed including the Throttle Body all for about $100 shipped.
Old Apr 2, 2010 | 11:13 PM
  #32
JDMC5's Avatar
my bad I didn't realize I had done that.
Old Apr 3, 2010 | 12:09 PM
  #33
neilownz's Avatar
I just got a tbss throttle body in the mail and it's 6 pin ls2 style connector if anyone was interested in that option. The truck intake would bump into the power steering no doubt.
Old May 12, 2010 | 05:36 AM
  #34
jderou_GXP's Avatar
Any update on this? Curious to hear your results!
Old May 12, 2010 | 02:55 PM
  #35
Nope still getting parts together. Just picked up sum ls6 yellow springs and scorpion 1.8 rockers. On a side note I did try hooking up the DBW truck tb and it didn't work so I don't know wtf is going on? I still have to figure that one out. I also still need to pick up a LS2 vally cover, catch can, push rods, and save a few pennies for the tune.
Old May 12, 2010 | 03:11 PM
  #36
supercatxr7's Avatar
Concerning the TB, you rewired and hooked it up? Would car not start or codes?
Old May 12, 2010 | 03:23 PM
  #37
Lmao wouldn't do **** it had so many codes it was stupid. When I first pluged it in and turned the key it would open a bit and close, but after that not **** car wouldn't even crank? I know the tb is good I checked it on my buddy truck opend and closed just fine. So I don't know what the deal is?
Old May 12, 2010 | 05:06 PM
  #38
LS1 Racing's Avatar
The GM truck DBW systems underwent a redesign sometime in the 2007-2008 model year. They went from a separate DBW controller box to having the functions integrated to the PCM. I believe that meant that the TB electronics were changed, too, which is why you had problems swapping it in.
Old May 12, 2010 | 05:41 PM
  #39
It's an 05' TB
Old May 13, 2010 | 08:05 AM
  #40
Brian396's Avatar
you rewired
what he said
