LS1 intake here I come!!!!!
Old May 13, 2010 | 09:09 AM
  #41
Haulin_Ls4_GxP's Avatar
Originally Posted by Brian396
what he said
Yep sure did
Old May 13, 2010 | 09:21 PM
  #42
Any ideas?
Old May 17, 2010 | 06:22 PM
  #43
Ok so I am going to use the ls2 valley cover. I am also going to do a catch can set up would it hurt to use the pcv line on the valve cover and the one on the valley cover?
Old May 17, 2010 | 07:28 PM
  #44
DavidGXP's Avatar
This is the route I'm heading for. Assuming, that the fitting on the tray, isn't in the way of anything.
Old May 17, 2010 | 09:23 PM
  #45
Yeah thats what I was thinking IDK if the box on the underside will hit the dod stuff. I guess we'll find out in about 2 weeks.
Last edited by Haulin_Ls4_GxP; May 17, 2010 at 09:23 PM. Reason: I'm stupid and can't type
Old May 18, 2010 | 11:19 PM
  #46
Ok so I got some more stuff done to the intake manifold. I put 3 new vacuum ports in one for the booster and 2 for the dual catch cans I’m going to run. I also just got the ls2 valley cover in should have the catch cans on Friday or Monday. All goes on starting the 28th and I have an appointment on the 2nd to get it tuned. Anyways here are some pictures of the manifold.
I changed it from what I had. Put in a 1 7/8'' freeze plug with some sealer around it
Old May 31, 2010 | 02:19 PM
  #47
DavidGXP's Avatar
Looking good buddy.
Old May 31, 2010 | 03:10 PM
  #48
Looking good buddy.
Can't wait till we get the adapter so I can get this thing on the car. So sweet thanks by the way
Old May 31, 2010 | 03:36 PM
  #49
DavidGXP's Avatar
Ha.. ha.. adapter. Yes sir, I just need to get may gasket and hopefully next weekend off. So.. so.. close man, I can't wait.
Old May 31, 2010 | 03:37 PM
  #50
DavidGXP's Avatar
What are you doing for injecters and fuel rail, any pics?
Old May 31, 2010 | 03:39 PM
  #51
I can't thank you enough for making this happen for all of us I'm sure I speak for everyone here when I say thanks for getting this together.
  #52
DavidGXP's Avatar
Dam.. went back through the thread. I remember now. (Hand slaps head..)
Old May 31, 2010 | 03:43 PM
  #53
LMAO yep stock injectors and rail. But at some point I think I might go with the LS6 rail and injectors like you did. I did't like hacking the mani like I did to make the stock rail work
Old May 31, 2010 | 03:54 PM
  #54
DavidGXP's Avatar
I just Ron is willing to make the adapters. He said that the adapter is pretty time consuming. Once I get this beast going, I'll give him a list of names and see what he say's. Right now he seems willing to do so.
I would love to use my stock injectors and rail, but I'm to lazy to make everything fit.
The best bet would be to cut off the crossover tube and weld the holes up on a LS6 rail and then have two fittings welded to the outside of the rail ends, in order to attach a braided hose. i would then use a tee to feed the fuel. This would work perfectly with stock injectors.
Old Jun 13, 2010 | 03:44 PM
  #55
Here are some pictures of the painted manifold.
Old Jun 13, 2010 | 06:55 PM
  #56
DavidGXP's Avatar
Gotta love that color. Especially in a black car. Lets get these manifolds going!
Old Jun 21, 2010 | 05:27 PM
  #57
So I just got the fuel rail mounted with the fender washers. I Might get the welder out and weld the washers to the rail but I'm being lazy at this point lol.I also go the TB adapter from Supercatxr7 and its mounted as well Thanks by the way. Just a few thing more to do and its going on
Old Jun 21, 2010 | 06:04 PM
  #58
monte_with_a_LS4's Avatar
looks good man! all i have to say is i wish i could put that under my hood
Old Jun 21, 2010 | 07:55 PM
  #59
DavidGXP's Avatar
Looking good and that TB adapter is killer! You should clean up those fender washers though. Can you grind them a little to shrink them down some? I would try a dab of JB weld. Hurry up!!!
Old Jun 22, 2010 | 11:39 AM
  #60
Yeah they are ugly. I don't think JB weld will hold them very well. i'm gonna try to weld them.
