Transmission Temps
Old Mar 16, 2010 | 03:06 PM
IAGXP's Avatar
I've always been told the hotter the trans gets the less the fluid is able to lubricate and lack of lubrication leads to most issues. Either way I went on the safe side and put one on my GXP. Anyone out there with a cooler have their trans go?
Old Mar 16, 2010 | 05:11 PM
LS1 Racing's Avatar
Originally Posted by XFiveLiter
LS1 Racing: What kind of cooler do you have? B&M?
Originally Posted by 1CL3ANSUP3RSPORT
^^ part number to PLEASE
Imperial Maxi-Cool XL. The part # is 243012. Basically, I took the car to my buddy's trans shop and told him to slap the biggest cooler on it that he could find. This is what I came home with:
It rated for a 30,000 GVWR, too!
Originally Posted by Tempest790
I don't have a trans temp gauge on mine, but I went with the finned aluminum pan by ZZP. Plus it has a drain plug.
According to Intense Racing though, coolers don't seem to help these transmissions from breaking. They stated that hard parts are what breaks in these. But, I do figure every little bit helps.
You can read more what they said here (scroll down about half-way):
http://www.intense-racing.com/techtips.shtml
Interesting, however, I gotta think that less heat in a tranny is a good thing and certainly can't be bad.
I'll keep my trans cooler!
Old Mar 16, 2010 | 07:43 PM
XFiveLiter's Avatar
That looks like the one I had on my Camaro. Never saw over 190 with 4400 stall and beating the snot out of it at the track. Might be a little overkill for our cars but it can't hurt.
Old Mar 16, 2010 | 07:45 PM
Mgpeagle's Avatar
I have 2 of those exact same ones. They are actually made by Hayden. I even think it say's it on the top of them. They are a good cooler. They are lined in series and NOT hooked up to the radiator. I still ran at 221* on the way home tonight. Gee, do you think my T.C is bad? I am so sick of this hot BS in the trans. Thank god I have a new one coming soon.
-Mike
Old Mar 16, 2010 | 09:33 PM
1CL3ANSUP3RSPORT's Avatar
[QUOTE=LS1 Racing;13042212]Imperial Maxi-Cool XL. The part # is 243012. Basically, I took the car to my buddy's trans shop and told him to slap the biggest cooler on it that he could find. This is what I came home with:
Thank you sir
Old Mar 18, 2010 | 12:06 AM
LS1 Racing's Avatar
So, I drove home back to LA from Phoenix today. I ran the westbound Chiriaco grade on I10 at about 80 MPH. Outside temperature arranged from 84-90 degrees. Highest trans temp I saw was 176 degrees.
Needless t oday, I think I have cooling on the tranny now, and would recommend this particular cooler to anyone wanting a little extra peace-of-mind.
Old Mar 18, 2010 | 10:43 AM
GXP25's Avatar
And only $49.99 from Advance [Discount] Auto Parts?
Install time?
Old Mar 18, 2010 | 01:32 PM
LS1 Racing's Avatar
Originally Posted by GXP25
Took about an hour.
Old Mar 18, 2010 | 03:18 PM
Nacho SS's Avatar
Seems like a good mod Mike. I know my trans temps have to be up there. This thing searches for gears so bad know.
Old Mar 18, 2010 | 04:22 PM
Haulin_Ls4_GxP's Avatar
I hit 226 the other day. It was about 60 outside. I'm tryin to get mine to blow so it can be built
Old Mar 18, 2010 | 04:37 PM
AlabamaGuy's Avatar
I heard of ways you can get it to blow that's completely undetectable...
Old Nov 15, 2016 | 01:28 AM
  #32
Brando5641's Avatar
I big cooler with a fan mounted towards the middle of the car. 2600 stall 4l60e turbo car. Usually hangs around 190-200
Old Nov 22, 2016 | 07:26 PM
  #33
Jason E's Avatar
Ancient *** post that got bumped, but I figured I'd chime in. I run TEP Max Cooler kits on both my LS4s. No idea what the ISS runs, but the GXP has never gone over 175 driving it hard. It could get up to 220 before on just an easy highway cruise.
I highly recommend that kit, and a cooler is essential to any LS4...stock or modded.
