Just installed my projector headlights..Monte SS
I bet the H3Cs are probably alot dimmer though
How the HID H3s are brighter? Sylvania Silverstars are just halogen bulbs, not HIDs or anything fancy.
The H3Cs im just guessing, cause they are quite a bit smaller than the H3s.
It could just be the Silverstars, they don't last very long to begin with, lol
This was taken as I was driving...And before I fully adjusted the lights...See how the right side extends farther than the left? It's supposed to do that..Some Euro sh*t called a kickup...So you can lightup all the signs on the side of the road without blinding other drivers...
I had no clue this even existed..I tried adjusting the lamps for a good hour and a half , trying to get it even..Then I gave up, went on google, and found out about this "amazing phenomenon"
In that pic, it looks like all the light is concentrated in the center...While it is brightest in the center..The light output is alot "smoother" throught the whole area...In this pic it looks like its only bright in the middle, then dull on the sides, when its actually pretty bright throughout.
On true quality projectors (Hella 90mm FX, TSX Projectos, Bosch etc) have two squirrel finders, one pure projectors so it looks like this:
What is the point of two? From what I see in the picture, it looks like it would still blind traffic, because the higher "slope" is on the right side of both of them? Sorry, I don't really know anything about these, lol
EDIT: After thinking about it, im guessing they would line up if the car wasn't so close to the garage...
Glad you guys are happy.
Like Nacho said, these are not true headlight projectors, hence the reason they use bulbs typically found in fog light applications. I still think that they produce better light output, compared to OE lights, and they look better "standing still," even when there are no working halos. Unfortunately, I've become a lighting "pro" with these and can fix them in a matter of minutes if something goes wrong....especially now that I have spare inverters laying around.
If I had the time/money, I'd take these apart and look to do a retrofit of actual projectors, but I don't have either of the above.
