Recommended Spark Plugs
Old Mar 28, 2010 | 05:12 PM
higsy's Avatar
Default Recommended Spark Plugs
Hey guys, I'm looking at changing my plugs next week when my headers get installed and since I'll be probably yanking my plugs, I was wondering what some of you guys use and what are the best ones to use. I've got about 60,000 miles on the car so it is probably in need for a change. I'm sure there are some better ones out there than stock.
Old Mar 28, 2010 | 05:34 PM
Nick_Nasty's_GXP's Avatar
http://www.pfyc.com/pc/GN3001/04UNDE...ark+Plugs.html
I was thinking bout getting the TR55IX plugs..a lot of $$ tho
Old Mar 28, 2010 | 05:38 PM
20SS06's Avatar
I got the ones in Nick's link and they're great...you'll definitely notice the power difference once you put these in.
Old Mar 28, 2010 | 06:00 PM
higsy's Avatar
Thanks guys. Did you change the plug gap at all or did you leave it at .059" ??
Old Mar 28, 2010 | 10:04 PM
20SS06's Avatar
I left it as it is
Old Mar 28, 2010 | 10:30 PM
Haulin_Ls4_GxP's Avatar
Try the E3 plugs I have heard nothing but good things about the. They will increase power and mpg.
http://www.summitracing.com/parts/ETP-E3-62/?rtype=10
Old Mar 28, 2010 | 10:50 PM
DavidGXP's Avatar
pulstar sells plugs that are 35.00 for the pair so if your made of money then....
http://www.pulstar.com/
or http://www.pulstar.com/howtobuy.cfm?...engine=1380035
Old Apr 1, 2010 | 11:46 PM
BadA$$'s Avatar
Has anyone tried these??? I read an article about 2-3 years ago...said they found a signifigant(sorry I can't spell ) power increase.
Old Apr 2, 2010 | 01:01 AM
neilownz's Avatar
Please. Just use stockers or ngk. I have bosch ir fusion ones in my car now.
Old Apr 2, 2010 | 08:12 AM
Mgpeagle's Avatar
I use XP-104's or XP-5243's by Autolite. I have the XP-5243's in now and get no knock. The 104's are one hr colder and the 5243's are 2. I have had the 53's in for over 1.5 years with no problems. By the way these are Iridiums.
-Mike
Old Apr 2, 2010 | 08:39 AM
higsy's Avatar
I went with the NGK Iridium's. These are going in on Monday when my headers get installed.
Old Apr 2, 2010 | 11:38 AM
DavidGXP's Avatar
Stockers are your best bet. They are a very well made plug, as well as the wires.
Stock plugs are about 5.00 a pop and last 100k and the wires are about 85.00 and have heat shields. Plus they are spring loaded so they won't pop off and won't break when you pull them off. GM went ***** out on our heads and ignition for some reason. i know the truck coils are better but I'm still impressed.
Old Apr 2, 2010 | 04:57 PM
BadA$$'s Avatar
Yeah, I read about the Pulstars...not many good reviews other than whats on their website.
Old Apr 2, 2010 | 05:32 PM
Sittingmongoose's Avatar
I run just basic stocks plugs and have no issues. I did put really nice ngk iridium plugs on my srt04 and it made a differnce but the plugs and wires in there sucked
Old Apr 2, 2010 | 08:04 PM
DP 08 GXP's Avatar
-Mike
same ones i got
Old Apr 3, 2010 | 07:02 AM
Tappeter's Avatar
Gotta laugh, there are so many false claims about spark plugs and so many gimmicks. Truth is: any well made good working plug with a sufficient spark will work just fine. Yes, an old worn out spark plug may not fire well or at all and foul and cost power. And some plug types will out last others. (Iridium) HOWEVER, DON"T believe all the crap about special fancy high price plugs adding all kinds of power, they just don't. A spark plug's job is to ignite the air fuel mixture in a compressed cylinder, period. If its a good plug with a decent sufficient spark, as most brand name plugs are, it will do that. Plugs claiming giant sparks with gobbs of extra horse power are a joke and a drain on your wallet only. Pour some gas in a bowl, through in a lit match or a burning log, which is going to make the gas burn and ignite? BOTH!!!!
There have been lots of real tests done with spark plugs and even spark plug wires. The same results each time: As long as the plugs and wires are well made and in good shape they work fine, but will add no EXTRA power unless they replace worn out malfuncting original parts that were actually losing power.
