Ported Intake Manifold Installed!!!
Old Apr 10, 2010 | 07:42 PM
Mgpeagle's Avatar
I sent you a Pm...
-Mike
Old Apr 10, 2010 | 07:49 PM
Nick_Nasty's_GXP's Avatar
Originally Posted by Mgpeagle
I didn't know in NY if they look under the caror not? If so, I have something you may be interested in.
-Mike
Yeah they do the whole 9 in NY
Old Apr 10, 2010 | 08:17 PM
DP 08 GXP's Avatar
has anyone tried to move the MAP sensor on the intakes?
Old Apr 10, 2010 | 09:34 PM
DavidGXP's Avatar
The ZO6 cam is perfect for our engines 02+ LS6
Its got a wide Lobe separation for a smooth idle with tons a of vacuum, and its got a lot more exhaust duration then the intake lobe to help with the restrictive exhaust manifolds and cat. No it's not to big. We have plenty of cam stock though. My engine with rockers will pull up to 6100.
Old Apr 11, 2010 | 05:58 PM
Thought I'd provide an update...so after a couple of days, I am hearing deeper exhaust tones, and definitely better throttle response. I had to work the last couple of days (weekends blow ), but I promise I will punch it sometime this week and tell you if I notice any changes.
Old Apr 11, 2010 | 06:07 PM
ImpSS07's Avatar
Are you on the stock tranny??
Old Apr 11, 2010 | 06:12 PM
Yeah, it's still going strong tho, so I don't plan on changing that soon (I hope)
GXP25's Avatar
Any idea about a better DOD/AFM camshaft? From the L76 (G8 GT)?
Old Apr 11, 2010 | 09:00 PM
neilownz's Avatar
I just got a bbk ssi aluminum intake pretty cheaply. Ill check the clearance issues with that. Hopefully the stock fuel rail will fit. Looks like a 5004 and I already have a truck tb to use with it.
http://www.bbkperformance.com/produc...-manifold.html
Old Apr 11, 2010 | 09:05 PM
Mgpeagle's Avatar
Wow, that's nice. I hope it fits. I'd love to see the numbers.
-Mike
Old Apr 11, 2010 | 09:32 PM
DavidGXP's Avatar
Just cut the back of your alt bracket off and get some injector adapters and that sucker will bolt right on.
Old Apr 11, 2010 | 09:33 PM
  #32
neilownz's Avatar
I saw some professional products ones on ebay for 345$ too, but I would trust bbk more. I'm sure they are similar. Aluminum intakes do have heat soak issues, but I would rather have a bigger opening.
http://www.professional-products.com...oldsLS1LS2.php
http://cgi.ebay.com/ebaymotors/Profe...Q5fAccessories
Old Apr 11, 2010 | 09:37 PM
  #33
neilownz's Avatar
Yea it's a salvage take off. No idea what size those included injectors are. Hoping to just use the ls4 ones.
Old Apr 11, 2010 | 10:27 PM
  #34
DavidGXP's Avatar
You could get away with LS6 injectors (28lb) but not LS1 26lb injectors without tuning.
You can get the injector adapters for 25.00 on E bay.
