DOH!! A/C not working...
uugghh... went to use the A/C the other day, cuz it was in the 80's and humid here... and it didn't work!! just blowing out hot air...
checked it out last night - compressor doesn't even sound like it's clickin' on when I push the A/C button on...
I checked the fuse for the compressor, and it's fine...
but, there's also a relay for the a/c compressor - and I'm wondering if that's shot - no way to tell by visual inspection...
any thoughts/ideas??
thanks!
thanks!
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
the light is solid... just like normal...
__________________
I would put a guage on the low pressure side to see if you have any pressure first. The compressor will not run if there is no pressure. Obviously if you don't have any pressure there is a leak. If there is pressure then it maybe the pressure sensor. Does anyone know if you can scan the hvac system for codes or read signals? Good luck.
well, looks like I just need a recharge... WHEW!!!
my pressure is too low in the system, so that's why it's not coming on...
and there IS pressure, so I know it's not a leak... I have about 81-83 psi in there...
so that's good news for me! whew!!
Thanks for everyone's tips/suggestions - it's appreciated!!!
__________________
