Fooling DoD...DONE!!
Old May 18, 2010 | 02:42 AM
JDMC5's Avatar
yeah with hptuners you can but he said he didn't want to do it that way.
Old May 18, 2010 | 05:46 AM
jderou_GXP's Avatar
Originally Posted by TiredGXP
No fooling around required, just change a flag value for third gear in two dod disable tables = done.
**edit**
Here's a pic of the tables - change the indicated zero's to "1"
Attachment 232833
Man, I do need to get that program. but still, I want to switch on the fly!
Took some measurements on that sensor. .5v with no vacuum and 3v at idle. Gonna pick up some things at radio shack tonight to vary the voltage between the two. Should be pretty simple, just turn the pot till the led turns off and see if I have any alarms!
Old May 18, 2010 | 05:56 AM
monte_with_a_LS4's Avatar
let us know how it goes!!
Old May 18, 2010 | 06:40 AM
TiredGXP's Avatar
Switchable?
The only non-software option I see is to put a switch in the power lead going to the DOD connector. You'd need to find a wiring diagram to see which wire this is.
the DOD solenoids are designed to fail "off", so without power, they can't switch the lifters into DOD mode - but, does this throw a code? If the ECM is commanding DOD, will it know that the solenoids have been prevented from operating? Will the fuel injectors for the cylinders the ECM is trying to deactivate continue to fire? I just don't know.
Old May 18, 2010 | 08:09 AM
JDMC5's Avatar
ahhhhh, that's a good idea. You could just set it into fail mode......more than likely is going to throw a CEL while it's on though. You'd have to shut these off. See attached.
Old May 18, 2010 | 08:14 AM
JDMC5's Avatar
BTW, here's what control we have over the DOD
Attached Thumbnails Fooling DoD...DONE!!-dod2.jpg   Fooling DoD...DONE!!-dod3.jpg
Old May 18, 2010 | 11:34 AM
jderou_GXP's Avatar
That's what I'm talkin about!
If I get a CEL I will have to wait till I can afford that.
"Honey, somethings broke on the car and its gonna cost $500 to fix it" lol.
Old May 19, 2010 | 05:54 AM
jderou_GXP's Avatar
OMG, it works!
turned it down below 2.2v and it shut off. Drove for about 10 minutes afterwards and it seemed normal.
I wired it up wrong at first last night and while I was trying to figure out what was wrong, with the ignition on-engine not running, an alarm came up that said "reduced engine power".
I fixed my wiring, but when I left to try it out this morning the CEL was on. So I'm not sure I know that this doesn't throw a code yet. Do you think it would have alarmed at me again if it threw the same code?
The inside of my car looks like a science experiment right now though, I need to get it installed cleanly.
Old May 19, 2010 | 06:10 AM
TiredGXP's Avatar
Some DTC's don't throw a code or set the CEL until the second error. That happens to be the case with DOD error codes:
Software solution (HPT) FTMFW!
Edit DOH, JDMC5 already posted a shot of the DTCs
Old May 19, 2010 | 06:17 AM
jderou_GXP's Avatar
Guess I'll clear the code and see if it happens again. Whats the best way? Autozone here won't clear them for you, just pull them. They claim it can damage some engines (BS, but anyway).
So should I just pull the battery wire? how long should I let it sit?
TiredGXP, can you look for errors related to low vacuum? Those errors look more like what you would see if you pulled the connector to the solenoids.
Old May 19, 2010 | 08:18 AM
94ss06gxp's Avatar
if this works with no CEL and no errors, you need to make a write up.
Old May 19, 2010 | 08:30 AM
  #32
jderou_GXP's Avatar
Will do! I'm not proud of my mess right now though, when I get done it should be minimally detectable.
Old May 19, 2010 | 12:00 PM
  #33
jderou_GXP's Avatar
I just cleared the codes and went for a ~10 minute drive.
I win, DoD Loses! Worked like a charm. No new CEL. Total cost to this point, about $6.
I could do it for less if I didn't want to be able to turn it back on.
I haven't actually tested the switch out yet though, it is full time off right now. The sensor is completely bypassed. Only issue that could come up with that is when flipping the switch, between sources, their will be an inbetween time where the ECM could see no voltage, and alarm.
If that happens I'll just have to get a little more creative with the circuit.
My first mod will either be called DoDoD, or AFMoD
Old May 19, 2010 | 12:16 PM
  #34
94ss06gxp's Avatar
creator od the DoDoD, i will need info on this in the next few weeks. this is awesome, good work sir.
Old May 19, 2010 | 12:57 PM
  #35
LuSe4's Avatar
Please keep us posted on this (I am sure you will!) Good job and my fingers are crossed that you beat the d.o.d.!
Old May 21, 2010 | 05:49 AM
  #36
jderou_GXP's Avatar
I'm at stage 2 now of this. I have the wiring more permanently installed, and everything is wired up as I plan it to be when I am done. The only thing I haven't done is make a mount for it in the car and try to blend it in with the interior.
Some blurry-*** pics to prove I'm not blowing smoke. I pulled out my old camera, apparently it has focus issues. and obviously the date isn't right.
Oh, and so far the on-off switch is working well!
That switch assembly will be scaled down majorly before it gets mounted. I think I should be able to fit it all in that slot between the console and the little glove box thing above it.
first pic is the tap into the DoD solenoid tray, for the led indicator.
second shows the finished wiring
third - switch
fourth - everyone needs a whiteboard at home!
fifth - starting the brake booster pressure sensor splice.
Attached Thumbnails Fooling DoD...DONE!!-dcp_1793.jpg   Fooling DoD...DONE!!-dcp_1795.jpg   Fooling DoD...DONE!!-dcp_1798.jpg   Fooling DoD...DONE!!-dcp_1790.jpg   Fooling DoD...DONE!!-dcp_1791.jpg
Old May 21, 2010 | 08:00 AM
  #37
JDMC5's Avatar
I was disappointed to see that stock airbox on there..
Old May 21, 2010 | 08:39 AM
  #38
jderou_GXP's Avatar
Along with all the other stock garbage, lol!
At least I have broken its cherry. Now I won't feel as bad about messing with it.
Old May 21, 2010 | 09:13 AM
  #39
JDMC5's Avatar
try looking at it as fixing what the engineers screwed up. lol
Old May 21, 2010 | 09:28 AM
  #40
jderou_GXP's Avatar
case in point: The intake neck...
