Fooling DoD...DONE!!
Old May 24, 2010 | 03:07 PM
  #61
jderou_GXP's Avatar
Originally Posted by Snyd's
Mines an 06 with a different ECM, so good point about potentially different values on different LS4 revisions.
I will plug in a 10K radial and dial to suit. Post my results here when they are available.
884 or 8.8 K? We cant calculate the voltage drop without knowing the current flowing thru the resistor. 1K seems reasonable to spoof the ECM, however 10K would probably appear as an open to the ecm. If you leave it totally open does it toss a code? Is the resistor totally needed to prevent it from setting a code?
Just thinking out loud.
We shall see.
Interesting stuff. Thanks.
Cheers
Mike.
Is the resistor needed? Good question! I have no idea, lol. I can tell you that with my accidental solder bridge, it would set the light after two startups. But then I never tried leaving the switch on with the resistor so I can't say it wouldn't do it also.
I think if you measure the resistance in the sensor, orange wire to yellow, it should be pretty close to the jumper resistance. Voltage divider says for 3.1v to go down to 2.1 with one resistor at 884 ohms, the other one must be around 450. If I recall correctly, I did measure that sensor resistance and it was somewhere around there.
I can say that for those of you that just want DoD off, jump the orange wire straight to the yellow, start it up a couple times till you get a light, remove jumper and reconnect sensor. DoD is now off.
Old Nov 7, 2010 | 07:40 AM
  #62
Adamcc91's Avatar
Originally Posted by monte_with_a_LS4
one time i forgot to shift it to drive and got up to 125 mph while in 3rd lol
Using the Paddles?...doesnt the car automatically shift if you get it up to high?
Old Nov 7, 2010 | 07:42 AM
  #63
94ss06gxp's Avatar
no, she just revvs
Old Nov 7, 2010 | 07:56 AM
  #64
Adamcc91's Avatar
Originally Posted by 94ss06gxp
no, she just revvs
OH, thats neat, I know most cars go into a safety mode and shift for you to protect it self
Old Nov 19, 2010 | 05:34 PM
  #65
vroom_vroom's Avatar
It's a Pontiac, she's built for performance
Old Nov 19, 2010 | 05:37 PM
  #66
Hawkins04's Avatar
mine revs for a second and if you dont shift it just fails on its face till you do
Old Nov 22, 2010 | 12:35 PM
  #67
havelegs's Avatar
DoD does not come on while shifter is in 3rd gear for my car. Only comes on in D for me.
Old Jul 12, 2011 | 04:43 PM
  #68
EmersonHart13's Avatar
Bump for switch.
Old Jul 13, 2011 | 08:59 AM
  #69
Jfhghs's Avatar
Default Write up ...... Write up!
I am not a genius when it comes to wiring but would love to see a detailed write up on this.
Old Aug 4, 2011 | 11:28 PM
  #70
LEDbetter's Avatar
Where is the write up?
