Got bored so I did this..
Old May 23, 2010 | 09:58 PM
DavidGXP's Avatar
Default Got bored so I did this..
Wrapped my CAI tube, with COOL IT THERMO TEC heat shield wrap. I trimmed a small section of material out and laced it on. Took about 15mins. I've been driving around all week with no problems. And according to my IAT readings, It's working great! Temp is about 7-15* hotter then ambient air temp while cruising. Sitting at a long light after getting off of the freeway, I still heat up, just not as bad. It takes much longer. I let my engine heat soak for a while, while getting something to eat. And after leaving the parking lot, I was only reading 88* on a 59* day. This was after driving around all day. Good mod for 50.00 bucks. The biggest thing that I have noticed is that after heat soaking my IAT sensor cools down much quicker.
Old May 23, 2010 | 10:01 PM
AlabamaGuy's Avatar
That's pretty cool! I might do this even with the HSRK.
Old May 23, 2010 | 10:08 PM
TiredGXP's Avatar
A couple of years ago, when trying to figure out IAT/ECT bias tuning, I insulated my MAF. Agree that it keeps things a bit cooler, and definitely cools down faster after heat soaking.
Definitely worthwhile.
Old May 23, 2010 | 10:22 PM
DavidGXP's Avatar
I'm going to relocate my IAT sensor next, and use the Omega 44005 resister.
http://www.redgto.com/kb/Article.asp...9&cNode=6P2Q8A
Old May 23, 2010 | 10:54 PM
Haulin_Ls4_GxP's Avatar
Link is broken. whats the 3rd to?
Old May 23, 2010 | 11:01 PM
DavidGXP's Avatar
Pat numbers in the first link wit a IAT sensor.Links deleted cause they don't work
Old May 23, 2010 | 11:18 PM
TiredGXP's Avatar
Or there's always this option:
http://kb.ls1gto.com/KB/article.aspx...9&cNode=6P2Q8A
Old May 23, 2010 | 11:24 PM
DavidGXP's Avatar
Much cheaper then Vector motor sports hsrk.
Old May 24, 2010 | 01:14 AM
JDMC5's Avatar
can I get that in a size 13? Haha, no seriously though, that's a good mod for exactly what you said, while crusing it won't make much of a difference but when you shut it down and let it sit for a period of time and then drive again you won't heat soak as much. Like for example with my HAI, I see about 5-10 above ambient while I'm cruising but if I park it for say ten minute and then come back my temps are well above 100*. They quickly cool off after I start driving again but you catch my drift.
Old May 24, 2010 | 05:16 AM
Tappeter's Avatar
I have done this exact IAT relocate. It was fairly simple if you have any soldering experience at all. I put the IAT in the end of the cone filter in my CAI box.
Old May 24, 2010 | 07:55 AM
LS4SPEED's Avatar
I think I would wire tie it rather than use a shoe lace. Just thinking about fire hazard or having it come untied and getting caught in something. Great idea though!
Old May 24, 2010 | 08:55 AM
2005gxp's Avatar
why remove the heat shield off the header crossover?
Old May 24, 2010 | 10:04 PM
DavidGXP's Avatar
Heat shield hit the tb to maf coupler.
Old May 24, 2010 | 10:21 PM
DavidGXP's Avatar
This little mod is really working. I can't believe the difference!
Old Jun 12, 2010 | 11:24 PM
DavidGXP's Avatar
Ground down the ears of the maf, and sprayed it out with some maf cleaner. The wrap now fits on a lot tighter, and I tucked away the bowties. My maf was dirty. It had small dust particles on the plate and black stuff went oozing out when I sprayed it.
Somebody else do this! I have extra wrap.
Old Jun 13, 2010 | 08:20 PM
Panther427's Avatar
sweetness. looks cool
Old Jun 13, 2010 | 10:04 PM
CenTexSS's Avatar
Originally Posted by DavidGXP
I have extra wrap.
Send it my way!
Old Jun 13, 2010 | 10:23 PM
DavidGXP's Avatar
Originally Posted by CenTexSS
Send it my way!
25.00 Split the cost?
