exhaust suggestions
Old Jun 10, 2010 | 04:02 PM
Panther427's Avatar
How much power did you put down 2005gxp
Old Jun 10, 2010 | 05:18 PM
2005gxp's Avatar
261whp and i think it was 267wtq
Old Jun 10, 2010 | 10:05 PM
monte_with_a_LS4's Avatar
i love the sound of mine. i want headers so bad but i cant spend the money right now.
also have no cat, they dont check in Illinois
Old Jun 10, 2010 | 10:16 PM
BigBlackBoxChevy's Avatar
I'm in the same boat. I want to get an exhaust (mostly for the sound) and I want to be loud w/o having straight pipes on it. I've read the Magnaflow cat-back is quiet?? I really want a Corsa or Borla Cat-Back but to my knowledge neither make one for the Impala.
Old Jun 10, 2010 | 10:18 PM
it will be on the expensive side, go custom. no one has ever done corsa, i think itd sound sick!
Old Jun 11, 2010 | 05:43 AM
williamGT's Avatar
My magnaflow cat-back is LOUD, took the resonator off and cat.
Old Jun 11, 2010 | 06:47 AM
TiredGXP's Avatar
It's gotta be. Even with the cat and resonator installed, mine's still loud enough to set off car alarms in the parkade at work.
Old Jun 11, 2010 | 08:25 AM
IAGXP's Avatar
I have cheap Thrush welded mufflers with the res removed and get complements quite a bit. I would like to remove my cat as well but the cost of the catless dp and tuner to get rid of the cel is a bit much given I just put in a new "used" motor and rebuilt trans.
Old Jun 11, 2010 | 08:53 AM
supercatxr7's Avatar
Can anyone verify for sure that a single 3" to 2.5" dual system made for a GTP will fit on a Monte Carlo?
Old Jun 11, 2010 | 10:06 PM
1CL3ANSUP3RSPORT's Avatar
I have the DT headers no res and Magnaflows,and I love the sound.Just need to tune her now...
Old Jun 11, 2010 | 10:17 PM
williamGT's Avatar
Hahaha, I set off a car alarm today.
Old Jun 12, 2010 | 03:07 AM
  #32
Nacho SS's Avatar
Catless DP --> No res --> Super44s
Rasp for days. Loud as hell. Turns heads. Sounds pissed. Stanks.
Old Jun 13, 2010 | 11:38 PM
  #33
I think I decided on an exhaust. Gonna keep the stock mufflers, and get an electric cut-out from DMH right after the Res, heard a couple of them and they sound nasty. Now I gotta find someone to weld it and wire it.
