Lowering the Imp
Old Jun 13, 2010 | 11:31 AM
Dannymik's Avatar
Default Lowering the Imp
I purchased a set of 18" SM Tach wheels from Tirerack and mounted them onto 255/45/18 tires and would like to lower her an 1" or so. I never lowered any of my casr in the past and would like to know what's all involved in the process...whats the recommended products out there for our cars?
Thanks
Old Jun 13, 2010 | 12:16 PM
monte_with_a_LS4's Avatar
Theres not much to it. SSC springs are the best springs made for this car. you might have some rubbing issues if you have 255s in the back.
Old Jun 13, 2010 | 12:46 PM
Dannymik's Avatar
Rubbing when it comes to going over bumps?
Old Jun 13, 2010 | 12:51 PM
pro_performer's Avatar
Yea, you would more than likely rub with the 255's when you hit a decent bump; however, it really depends on how far the wheels and tires stick out.
If you do rub after you lower your impala, you may be able to roll the fenders to stop it.
Old Jun 14, 2010 | 08:33 AM
BuffaloSS's Avatar
One of two big mistakes I made was to put 255's on my wheels. Rubs on the lip of the QP pretty badly, and rubbed on the spring perch as well. When I lowered it, it rubbed even MORE. Also, I'm surprised TR allowed you to put 255's on the 8" wide wheels...that's the bare minimum width, and it's not always recommended.
Regarding lowering the car, reuse the stock struts (or buy new OE struts*), install the SSC's, install camber alignment bolts, install anti-pogo washers, and, depending on how many miles you have on her, consider replacing your strut mounts.*
If you're doing this yourself, buy (and promptly resell afterward) a fender rolling kit. You can also rent them from places on ebay and elsewhere. You're probably going to need to do this even if you don't lower it, since you put the 255's on. It may only happen on bumps or when the trunk is loaded, but it's a nasty sound to live with. Shops may charge $200 to do this for you, and they still may crack the paint.
*I'd do the mounts and replace the struts only if you have more than 50k on her, and for a 2008, me thinks that would be tough to achieve.
Old Jun 14, 2010 | 11:28 AM
Aaron_Provost's Avatar
SSC lower your car 1.7" in front 1.5" in rear, I would also like to get my car lowered but not that much
Old Jun 14, 2010 | 11:47 AM
BuffaloSS's Avatar
IIRC, the Eibach kit is 1.2" F/R, and the only other setup is by Sprint, and I don't recall anyone ever going that route.
Someone pointed me to spring spacers a while ago...they recommended them b/c I didn't like how much lower the rear appears. It's just the shape of the rear QP that makes it look that way, though. I haven't R&R'd the rear springs yet, but will likely install the spacers when I do so.
Old Jun 14, 2010 | 02:13 PM
Ill_Born_ss's Avatar
http://www.bilsteincanada.com/index....9045_9064_9070
http://www.essexdistributors.com/ind...=1_552_593_601
http://www.moog-suspension-parts.com....asp?cat=11264
Old Jun 14, 2010 | 05:48 PM
2005gxp's Avatar
im lowered on ssc's and if i have 1 other person in the car i rub everywhere, running 245/45r18 tires
Old Jun 14, 2010 | 07:46 PM
Dannymik's Avatar
Maybe I will not lower her cas the 255's seem like a huge mistake especially with the SSC springs...Maybe I can unload them over the winter for some 245's
Old Jun 14, 2010 | 08:03 PM
GXP25's Avatar
Our cars come with 255 up front on 8" wheels... Highly warrantied by GM...
245 all around? Maybe you might need some spacers in the rear.
I'm lowered 2.5" in the front (255/45-18) and 2.0" in the rear (225/50-18) and don't rub whatsoever.
Old Jun 14, 2010 | 08:32 PM
Dannymik's Avatar
(Buffalo SS) I forgot to mention "The Red Dragon" has a little over 28K on the clock, so the suspension is still riding very good
Old Jun 15, 2010 | 09:59 AM
BuffaloSS's Avatar
What did you do to achieve a 2.5"/2" drop? Pics?
I thought the GXP came with 245's on the front...my mistake.
Old Jun 15, 2010 | 10:11 AM
Dannymik's Avatar
Actually my Imp has 29700 on the clock
Old Jun 15, 2010 | 02:23 PM
GXP25's Avatar
SSC/Canuck Motorsports springs.
Old Jun 15, 2010 | 02:50 PM
Nacho SS's Avatar
SSC springs are 1.6/1.8 IIRC...
Old Jun 15, 2010 | 05:43 PM
Nick_Nasty's_GXP's Avatar
My GXP has about 52K on it and I never really thought about lowering her until recently. If I do end up lowering her, would you recommend that I replace the struts also?? I ask because word of thumb is: replace the springs, replace the struts
Old Jun 16, 2010 | 06:54 PM
SSC Springs are 1.7/1.5 for 2006-2008 Monte Carlo SS #21-2921
1.6/1.6 2006-2008 Implala SS #21-2721
1.7/1.7 2004-2007 Grand Prix #24-5221
http://www.superiorsportchassis.com/..._app_guide.pdf
Old Jun 16, 2010 | 07:12 PM
GXP25's Avatar
Mine were 2.5"/2.0". Eventually, there will be a GXP kit with 2.5"/1.5".
Old Jun 16, 2010 | 07:47 PM
i wish they would do that for the monte. or atleast in the front. then make the back like 1 in or something. the backs sit low enough the way it is
