GXP Brake upgrade for an 2006 Impy SS
Old Jun 14, 2010 | 03:38 PM
98GTcoupe's Avatar
Default GXP Brake upgrade for an 2006 Impy SS
Hey all,
Just like the title says. Got a buddie runing 24in Wheels on his Impy SS. Well he has been complaining that it stops like ****. So i said why dont you get my brakes for it. Well he is not a gear head at all.
What are the differences in the impala ss and the GXP? And it looks like ill be putting them on his car, cuz he has no clue, which is all good cuz he can watch an learn....
EDIT: 22in Rims not 24in.. SORRY!!
What all will we need besides the obvious?
Thanks
Greg
Old Jun 14, 2010 | 03:53 PM
04DetroitLS's Avatar
unless yours are twin piston calipers, I doubt it will have any big effect on it....
AFAIK, the GXP rotors are 12.7"(IIRC) and the Impala came w/ 11.9" (atleast 04 prior)
If he wants to improve it, there ARE big brake kits avail ($1k+) or he can use LS1 calipers and brackets (twin piston alum v/s his single piston cast) or see if the 06+ Lucerene calipers are a direct swap (again twin piston calipers)
w/ 24's on his caqr hes going to run into bigger issues, IE trans...
he's not stopping as well b/c he prob has almost twice the weight on each hub v/s his stockers......
Old Jun 14, 2010 | 04:52 PM
Nick_Nasty's_GXP's Avatar
Tell him to dump the 24's...then he will be able to stop MUCH better
Old Jun 14, 2010 | 06:18 PM
98GTcoupe's Avatar
I havent done any impala front brakes arent they already dual piston. HIs car is a 06 SS. So would it be worth it to upgrade to the 13in GXP rotors/Calipers. I would think there would be with 13in up front and 12in out back....
Old Jun 14, 2010 | 07:12 PM
AlabamaGuy's Avatar
Would GXP brakes be a bolt in item?
Old Jun 14, 2010 | 07:15 PM
Flip's Avatar
Yes.. They will bolt right on..
Old Jun 14, 2010 | 09:21 PM
havelegs's Avatar
Are the gxp brakes better than the impss?
Old Jun 14, 2010 | 09:46 PM
pretty sure theyre still single....
rockauto lists:
A-1 CARDONE Part # 164988 {[Caliper w/Installation Hardware & Pad] Reman.}
Front Left; OE Metal Piston
wouldnt be the first time they were wrong though
Old Jun 15, 2010 | 07:01 AM
98GTcoupe's Avatar
Im gonna keep hunting and searching.
I do know that you can get a set of DTS front Calipers off an 06-08 models. They are the same caliper as the GXP, just not painted. Same as the rears but I think the parking brake cable connection maybe different..
Old Jun 15, 2010 | 07:22 AM
98GTcoupe's Avatar
This looks like a complete shopping list...
Part Price Core Quantity Total Remove
2006 PONTIAC GRAND PRIX GXP 5.3L 5328cc 325cid V8 FI (C) OHV
Brake/Wheel Hub : Rotor
RAYBESTOS Part # 580381 {12.718" / 5 Bolts / Cross Drilled Advanced Technology}
Front; GXP B
$60.79 $0.00 $121.58
RAYBESTOS Part # 580365 {Advanced Technology (Only 4 Remaining)}
Rear; FE4 Special Suspension B
$61.79 $0.00 $123.58
Brake/Wheel Hub : Caliper
NASTRA Part # 114777 {Reman Semi-Loaded (Only 1 Remaining)}
Rear Left A
$68.79 $25.00 $93.79
NASTRA Part # 114776 {Reman Semi-Loaded (Only 1 Remaining)}
Rear Right A
2007 CADILLAC DTS 4.6L 281cid V8 FI (9) DOHC
RAYBESTOS Part # FRC11911 {Professional Grade; Friction Ready - Pads Not Included, Remanufactured #FrontLeft5StudRotors, FrontLeftContainsBra, FrontLeftCXLContains, FrontLeftSuperContai}
Front; Left; 5 Stud Rotors; GM Brake Code JL9; Contains Bracket C
$57.79 $75.00 $132.79
RAYBESTOS Part # FRC11912 {Professional Grade; Friction Ready - Pads Not Included, Remanufactured #FrontRight5StudRotor, FrontRightContainsBr, FrontRightCXLContain, FrontRightSuperConta}
Front; Right; 5 Stud Rotors; GM Brake Code JL9; Contains Bracket C
Subtotal $698.32
Old Jun 15, 2010 | 10:04 AM
BuffaloSS's Avatar
The Impala front brakes are dual piston.
Old Jun 15, 2010 | 11:06 AM
dont you have anything better to do than follow me around and contradict everything I say.... LOL
Thanks buff... wasnt sure, was just going by the crappy pix/limited info i could find online
Old Jun 15, 2010 | 11:27 AM
BuffaloSS's Avatar
lmao. WTF you doin at LS1tech anyway? You don't belong!!!
Old Jun 15, 2010 | 11:52 AM
I dont belong ANYWHERE near teh intrawebz LOL...
Registered here when i bought the FBody, been lurking since.... gotta post ***** up a bit so i can make threads in the class section, need lots of parts LOL
Old Jun 15, 2010 | 12:09 PM
BuffaloSS's Avatar
***** away! (not like you need instruction )
Old Jun 15, 2010 | 01:24 PM
98GTcoupe's Avatar
Yeah so here's the plan. I told him to stay with the F-body/Impala DUAL piston calipers and we are gonna slap some GXP rear brakes on with good rotors and some good pads. Also some drilled rotors for the front with good pads.
Something to help him stop those fuggin 22in wheels.... Those rear brakes look pitiful on that car. lol.
Old Jun 15, 2010 | 03:20 PM
TheMonteMan's Avatar
https://www.zzperformance.com/grand_...1041&catid=138
they also have the rears and the fbody stuff as well. arent the fbodys 12" the same as whats on there just aluminum?
Old Jun 17, 2010 | 11:02 AM
Striker's Avatar
I believe the GXP calipers are PBR twin piston ones just like the C5 Vette. I recently did a rotor swap on it and the rotors where just under 13 inches-so again just like the Vette's. F body front rotors are 11.9 inches....
There always seems to be so much misconception on forums lol and I didn't even read the whole thread.
Old Jun 17, 2010 | 05:58 PM
thats what i thought so switching to the fbodys would be pointless.
Old Jun 19, 2010 | 07:49 AM
Count of Monte Carlo's Avatar
Tell him to bleed the brakes!
