2007 Impala LS DRL Problem..
Old Jun 17, 2010 | 12:28 AM
spauldo's Avatar
Default 2007 Impala LS DRL Problem..
First off this has nothing to do with these cars you have listed... But from doing a little internet research... I've been led to this website because it seems you guys are pretty smart and know what your doing vs all the morons I've dealt with at all my local car dealerships! If this is off key or annoying for this forum... Please accept my APOLOGY in advance... Just looking for some guidance from a few fellow smart car guys!
I have a 2007 Impala and starting about 3 days ago the DRL's.. Daytime running lamps... WOULD NOT go off whatsoever... Even after turning car off... Switching the car to automatic lights off, pulling fuses, everything simple anyone could think of... Even Unplugging and replugging in battery and changing fuses... Has anyone ever heard of this issue or know of any possible resolution would be awesome... Thanks in advance!
Josh
Old Jun 17, 2010 | 12:53 AM
stlsillest's Avatar
Josh
sounds like your DRL relay is sticking....try locating the relay and check to see if its properly functioning
Old Jun 17, 2010 | 05:56 AM
monte_with_a_LS4's Avatar
its impossible for them to stay on if you have the fuse out.
Old Jun 17, 2010 | 06:29 AM
2005gxp's Avatar
If you have autoheadlights pull that fuse, even try putting the ebrake on it usually disables drl's.
Old Jun 17, 2010 | 10:29 AM
spauldo's Avatar
Yeah I've pulled all the fuses... Replaced them... And messed with the E-Brake... Very frustrating to say the least.
Old Jun 17, 2010 | 04:22 PM
spauldo's Avatar
Ok..... So I've pulled the left and right parking lights fuses... And they've been disabled... I'm assuming it's the trick for me? Not sure but it seems to be working now..
Old Jun 17, 2010 | 08:35 PM
Red06SS's Avatar
The BCM also controls just about everything in the car, it's not an uncommon part to fail.
Old Jun 17, 2010 | 10:44 PM
CenTexSS's Avatar
It sounds like a short to power somewhere in the wiring after the fuses.
