Question about slicks (Installed Pics Inside)
Old Jun 23, 2010 | 04:30 PM
2005gxp's Avatar
Cool Question about slicks (Installed Pics Inside)
Ok, so I now have a set of MT slicks for my gp gxp, they are 26x11.5 17, they will be on 17x9 rims if that makes a difference.
My questions are,
what psi should I run in them as a geleral pressure? I know adjustment will be needed but want to know where to start, and rear tire pressure should be at the max?
Are race tubes necessary?
Also, is it benificial to race without a hood if I am able to?
Old Jun 24, 2010 | 12:35 AM
AlabamaGuy's Avatar
Straight up wrinkle walls? get ready to change your sig to say "3rd Tranny"
Old Jun 24, 2010 | 11:39 AM
smokin06impala ss's Avatar
I run mine @ 20 psi I've had about 20 passes on them and tranny still in one piece (knock on wood) .
Old Jun 24, 2010 | 11:56 AM
AlabamaGuy's Avatar
Slicks or drag radials? There is a BIG difference....
Old Jun 24, 2010 | 03:29 PM
Slicks 26 x 10.5 r16 M/T ET streets
Old Jun 24, 2010 | 04:29 PM
2005gxp's Avatar
im running et streets also
http://www.mickeythompsontires.com/s...?item=ETStreet
Old Jun 24, 2010 | 07:30 PM
AlabamaGuy's Avatar
ET Streets are drag radials.
Old Jun 24, 2010 | 09:38 PM
CenTexSS's Avatar
Definitely run WITH your hood. You'll kill your aerodynamics without it. I lost 3-4mph when I ran my old Civic without a hood.
I haven't ran slicks since 2003, so I'm not quite sure what pressures to run 'em at. I'd start around 18 PSI or so and work your way down until you find the sweet spot.
Old Jun 24, 2010 | 09:58 PM
2005gxp's Avatar
alright, so run with my hood on but ill pull my headlight, ill start the psi at around 18psi and work it down and run with my rear tire pressure at max(44psi i believe it is for my tires).
What about race tubes? would they help me at all?
Old Jun 24, 2010 | 10:05 PM
My bad now I know
Old Jun 24, 2010 | 10:19 PM
CenTexSS's Avatar
Maybe if you had a wrinkle wall slick lol
You don't need 'em.
Old Jun 24, 2010 | 11:18 PM
AlabamaGuy's Avatar
MT recommend what... 20 or 25 psi?
http://www.youtube.com/watch?v=d4f8MMi73PQ
Be sure to heat them up better than I did...and don't launch on the floor...like I did.
Old Jun 26, 2010 | 09:46 PM
2005gxp's Avatar
also forgot lol should i balance my slicks?
Old Jun 27, 2010 | 12:22 PM
CenTexSS's Avatar
I would, mine weren't balanced perfect - but weren't bad. It'd be a bitch to get a **** ton of steering wheel shimmey at 100+mph.
Old Jun 28, 2010 | 05:56 PM
2005gxp's Avatar
Installed! fit perfectly
Car is filthy btw lol
Attached Thumbnails Question about slicks (Installed Pics Inside)-sig.-pic.jpg   Question about slicks (Installed Pics Inside)-img_1371.jpg
Old Jun 28, 2010 | 06:27 PM
XFiveLiter's Avatar
There are bias ply ET Streets, they are basically slicks with small grooves in them to make them street legal but you DO NOT want to get caught in the rain with these. ET Street radials are completely different stiffer sidewall and SLIGHTLY better in the rain.
I wouldn't use tubes if these are strictly for track days. The air will bleed out after a couple days but who cares? Tubes add weight and are an unnecessary expense IMO.
Old Jun 28, 2010 | 11:21 PM
Look nice........ Btw did you take them for a spin to see if shake? Mine shake @ about 60mph
Old Jun 29, 2010 | 12:30 AM
Nacho SS's Avatar
polish your car one time...yeesh
Old Jun 29, 2010 | 02:03 AM
JDMC5's Avatar
hahaha, you should see my cousin's car. You would probably strangle him.
Old Jun 29, 2010 | 05:51 AM
2005gxp's Avatar
no shakes, running 25psi in them right now. and ya my car is due for a good polish lol
