Cam and heads in the works
I am thinking 300whp.
I have reworked heads, 1.8 rockers, LS1 intake, CAI, Custom 3" into Dual 2 1/2" exhaust, and tuning is pretty close.
So.. 330-350ish? (this would be setting the bar pretty high though..) I bet 330whp.
The only car that I can compare too would be Sittingmongoose, but his car was acting up on the Dyno and they did a 2nd gear pull. He made 320 something whp. (Low..)
Time will tell man...
If.. I can hit 330 then I'd be making about 75 more hp. This is petty reasonable IMOH.
Intake, cam, and exhaust.
I ended up breaking a 15/16" socket before getting the balancer bolt lose. Had to use a breaker bar with my jack handle atached. Exhausting!
DOD cam is gone with the lifters. I'm also using my LS2 valley tray.
I've gotta make a trip to the machine shop tomorrow to see if they can remove two broken rocker bolts. I used some HD industrial strength red loctite and the S.O.B's didn't wanna budge..
Here are a few pics..
Pulled the body from the frame with my Cherry picker. Thanks for the idea Nate!
Motor shot
Cam out
Cam in.
Getting the cam gear back on anf lined up was a major PITA!
Car is back on the ground waiting for the heads
One of the broken bolts. Pretty pissed right now..
LS6 intake and LS2 tray.
