Cam and heads in the works
You've got enough overlap that you'll be setting misfire codes and catalyst efficiency codes (if you still had a cat, and didn't already have that disabled!). There isn't any way to prevent the mis-firing (that's what lope is), but Lew can take care of the code for you.
The cam idles pretty rough... Sometimes I'm pulling 12"hg in drive and I can feel the power brakes get soggy. As said before, the engines smooths out when a little throttle is applied.
Everyone knows how I feel about big cams and this is about as big as I would wanna go with 2.93's. People think that we need to lose a little bottom end to gain some traction, and I disagree. The 2.93 gears really suck and make 2nd gear last forever.
Bottom end (idle to 2000rpm) is a little weak, but once I come up on the converter it's light out. The pull is amazing..
Power from 4500-5900 (stock shift) has been increased. After about 80mph at WOT in 2nd gear, the car starts to get a little squirly.. No joke! Tq steer is very noticable at higher speeds. Not the fastest car but definitely fast.. got killed by a Newer Cobra thinking it was a GT.. Dooh!
Sounds very lumpy at idle.. My car no longer sounds like the stinking trucks.. It's fun to watch people stare in parking lots when I cruise thru. It's obvioius that Im not stock.
I tried to get a sound clip but the quality is horrible on my phone. I'll have to figure something out for you guy's.
Install was done by myself. No help and it took me 6 days. The steering shaft, front cover hose clamps, and the power steering line took up a bunch of time.. I had to replace my PS pump cause I snapped a mounting ear off. I also Snapped my cam sensor and broke two rocker bolts. My G/F's kid broke his arm and I found out my Grandparents passed away.. They lived to be 88 so I can't complain. I also had to go to drill onlyt to get sent home cause of Obama. It was nice to relax this weekend and mourn a little.
I would do it all over in a heartbeat! Stock cam sucks *****!!
I still need to get tuned, so with the listed mods, and tuning, I am hoping for another 20whp which should put me at 390-400. With my dyno luck, I will probably only best 365
LMAO!!I have raced, and out MPH many of cars who have dyno'd 400+ HP so go figure... These cars just suck on dyno's.
you're my hero lol. btw what's you're mos? David?
